oil problem?
Woke up today and tried to start my car and it didn't want to start checked fuel pump relay and then I checked the sparks and wires but when I took out the sparks three had oil on them so I cleaned them up and car started. What's causing the oil to be on the sparks any guesses?
if oil is on the tip of the spark plug than you either have bad lower spark plug tubes seals or bad rings letting oil into the combustion camber.
link to replacing spark plug seals. you would be interested in the ones under the rocker assembly
http://www.cb7tuner.com/vbb/showthre...lug+tube+seals
this is all in the FAQ section btw
red civic standard
Jun 7, 2004 03:53 PM
