Dropped my oil pan and found tiny stones!
Old Feb 7, 2011 | 08:10 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Dropped my oil pan and found tiny stones!
I finally dropped the oil pan on my B18C-R swap to replace the pan gaskets which has been leaking pretty much since I got the motor. When I went to clean out the remaining oil inside, I noticed a couple (3) tiny crumb sized stones in the bottom, as well as a bit of grit in the places where oil slowly runs off the baffles.
I would like to know if this is normal or not? I've never removed an oil pan before so I didn't quite know what to make of it.
Everything else inside was amazingly clean. The plan cleaned up easily and the inside of the block is all shiny silver. I would have to say the original Japanese owner must have taken pretty good care of the engine (except for allowing stones inside <_<).
Now that I think of it, I suppose it could also be from removing the pan itself. A lot of dirt was falling out of the splash guard as I worked the pan out. Either way, any experienced opinions are welcome.
Old Feb 7, 2011 | 08:17 PM
clys's Avatar
Default Re: Dropped my oil pan and found tiny stones!
When I did the oilpan on my Starlet, there was knurled up flat metal chunks in it, looked like toasted bearings, however the motor ran fine and had no oil issues. I did blow it up however.
Old Feb 7, 2011 | 08:21 PM
Former User's Avatar
Let's go with this theory and call it a day.
^Not comforting
Old Feb 7, 2011 | 08:35 PM
94eg!'s Avatar
#1 Super Guy
Loved
Uh....I like the other guys idea better... lol
STN_Pat
Nov 29, 2012 04:05 AM
blackeg
Jun 6, 2009 11:06 PM
touandcim
Feb 22, 2008 08:58 PM
civickiller
May 17, 2003 08:35 AM
