Suspension & Brakes Theory, alignment, spring rates....
alloy rear lca - benefits and problems
Old Feb 7, 2011 | 07:07 PM
exquisit's Avatar
Default alloy rear lca - benefits and problems
looking for more info on lca for the rear
i have done a search and i have gathered that:
-they are shorter than standard lca which means wider and more negative offset wheels
-bushings are **** house which means they need to be changed to polys
is this true?
also, how strong are they?prone to breaking?
im not looking at function 7, more like omni/blox/etc branded style ones
thanks
Old Feb 9, 2011 | 01:58 PM
blowededup's Avatar
Default Re: alloy rear lca - benefits and problems
The LCAs should be the same size as OEM, or it wouldn't reach the subframe
Strength you are referring to I assume is the bushing in the control arm. I have been running Blox for ~2 years and have had to the replace the bushings twice already and I was planning on doing it again. They are junk. I will be trashing my set (unless someone wants them) and buying Skunk2's with the poly in them.
Old Feb 9, 2011 | 03:19 PM
exquisit's Avatar
yea i was reading that it brought the wheel more inside the well so you could run lower offsets n wider wheels lol
guess not
isnt it possible to push poly bushes in the blox lca?
i only ask this coz if there havent been any actual lca breakages, i might buy cheap ones with adjustable swaybar mounts and then replace the bushes with poly bushes
i have a feeling that they dont use oem honda sizing tho which would mean that i cant use poly bush kit
Old Feb 9, 2011 | 04:40 PM
grumblemarc's Avatar
The Grumpiest
I've never seen adjustable swaybar mounts on an LCA. Got a link?
Old Feb 9, 2011 | 04:41 PM
exquisit's Avatar
function 7 ones have adjustable mounts
Old Feb 9, 2011 | 04:48 PM
BlueIntegraBoy's Avatar
I haven't seen any pics or heard of snapped aftermarket LCAs.
Old Feb 9, 2011 | 04:50 PM
The Grumpiest
I see a choice of mounting locations but not anything that's adjustable. Anyway. As was posted on an old thread; OEM is best. The rest is for show. Blox seem to be 50/50. Anything less than F7 or S2 isn't really worth it.
Old Feb 9, 2011 | 04:54 PM
Here are adjustable LCAs (one of a kind)
http://sphotos.ak.fbcdn.net/hphotos-..._2785435_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._7548076_n.jpg
Old Feb 9, 2011 | 05:13 PM
exquisit's Avatar
sorry should have chose my words better
yea thats what i meant...multiple mounts lol
Old Feb 9, 2011 | 05:16 PM
Libertariat's Avatar
Ek Forever y0!
Save your money and buy the Function7 control arms. You'll be much happier in the long run. Lifetime warranty, better product, easy bushing replacement.
These forums have seen hundreds of torn bushing LCA threads for blox, skunk2, etc LCAs
Old Feb 14, 2011 | 11:40 AM
::ek-4::'s Avatar
My friend is selling me used Skunk2 lower rear control arms for $50. Are you saying its not worth it since the bushings will rip again?
Old Feb 14, 2011 | 12:16 PM
98civdx's Avatar
Master Detailer
There newest bushings are supposed to be alot better then the last ones. However I have heard the weren't but then again, the people saying they suck are well known to bash skunk2.
I personaly wouldn't bother. OEM/Function7 or noithing.
Old Feb 14, 2011 | 01:00 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
OEM and Function7 are the only LCA's worth 2 nickels. Use one or the other, anything else is pointless.
/thread
Old Feb 14, 2011 | 02:26 PM
phunhaus's Avatar
To those that think otherwise, there ARE some LCAs that are shorter in length to compensate for WIDER rear wheels:
http://www.spcalignment.com/PROD_DIR...d2=69100&cmd3=
If the aftermarket bushings are crap, then why even bother buying the arm? Get a good quality arm like Function 7 and don't deal with the bullshit. If people stopped buying shitty products and supporting companies that roll out ****, they wouldn't bother bringing that to market.
Buying **** begets more ****.
Old Feb 14, 2011 | 03:26 PM
Tyson's Avatar
thanks
then theres no point in wasting your money for inferior parts and far worse than OEM.
the bushings on all of those are horrible. only function 7 has a well designed bushing that properly addresses the issues of a poly bushing. and the ones that use an oem looking rubber bushing are worse.
and if anyone says anything about "lightweight" or "unsprung mass", youre full of it if you think that matters.
Old Feb 15, 2011 | 08:00 AM
::ek-4::'s Avatar
Thanks for all the help guys. Ordering some F7 control arms now. My polished ASR subframe and beaks lower tie bar came in today! :-)
Old Feb 15, 2011 | 09:29 AM
Ek Forever y0!
Why did you order the beaks? I guess it looks cool. More stuff for people to see under your car.
Most opossums to catch.
Old Feb 15, 2011 | 10:24 AM
::ek-4::'s Avatar
I got the Beaks bar for $40 shipped from a friend. I had to do it!!
Old Feb 15, 2011 | 10:25 AM
::ek-4::'s Avatar
I just saw the last line. Hahaha!! When i finally slam my car i will be sweeping the street's roadkill.
Old Feb 15, 2011 | 10:27 AM
Ek Forever y0!
For $40 I can't say I wouldn't do it for bling either.
CivicSiRacer
17
Mar 24, 2013 11:41 PM
Slimer
Suspension & Brakes
Jul 20, 2008 08:56 AM
beanbag
Sep 14, 2007 09:10 AM
Lyonel 13H4
Aug 25, 2004 08:07 PM
