fuel pump
Old Feb 7, 2011 | 01:15 PM
slowboy90's Avatar
Default fuel pump
will the new dw300 or the aeromotive 340 intank make 650hp? thats all i want this year next year i will be a fuel cell so i will need a new setup
Old Feb 8, 2011 | 04:12 AM
xenocron's Avatar
Default Re: fuel pump
The DW pump flows about 17% more than a comparable Walbro Pump...if you agree that a Walbro can make about 550-600 hp on its own, then a DW300 pump can make 640-700 but of course you will be at about the MAX the pump can make which is really never a great place to be.
Old Feb 8, 2011 | 04:28 AM
SLIM NOTHING's Avatar
yeah a buddy of min pushed his... it was a sad day
Old Feb 8, 2011 | 05:01 AM
slowboy90's Avatar
what about the 340lph aeromotive it should make 650 easily next year im going fuel cell and a new motor
Old Feb 8, 2011 | 07:10 AM
Deatschwerks's Avatar
What kind of fuel are you looking to use? I don't see 650hp on gasoline being an issue. E85 would be stretching it on either pump.
Old Feb 8, 2011 | 07:24 AM
slowboy90's Avatar
pretty sure i will be running 116
Old Feb 8, 2011 | 12:07 PM
xenocron's Avatar
Well, havent seen good data on this one yet...but yeah, it SHOULD give you more if it delivers what it says it will.
340/255 - 1.33 or 33% more or around 730 hp give or take.
Old Feb 10, 2011 | 08:14 AM
BoostkingB18's Avatar
Will 2 intank DW300 Pumps Make 700whp whit E85?
Old Feb 10, 2011 | 09:41 AM
Yes, 2 DW300 pumps should be able to support 700whp on E85.
Old Feb 15, 2011 | 08:14 AM
slowboy90's Avatar
Well i am having trouble getting the 340 intank and also was told it may not support my power so im going to do the old trusty walbro intank which i already have installed and a bosch near the rail but jays racing has pumps they say outflow the bosch inline im looking for some insight?
Old Feb 15, 2011 | 09:55 AM
DeLucia's Avatar
Why not do a intank 255 and inline 044?
Old Feb 15, 2011 | 11:17 AM
slowboy90's Avatar
thats currently what im thinking about doing i have a 255 intank
Old Feb 15, 2011 | 11:24 AM
You should be able to support that much power on gas.
What issues are you having with the install?
Old Feb 15, 2011 | 11:57 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
till what PSI? After 80 that Jay's racing pump is done.
Old Feb 15, 2011 | 12:00 PM
slowboy90's Avatar
well i will be running 1600's im going to be running 25 psi of boost
Old Feb 15, 2011 | 12:13 PM
You'll need ~260LPH of fuel to support your hp goal. ...and with the size of your injectors, you can afford to run a lower baseline fuel pressure. With your baseline around 40psi and 25psi boost, you should be hovering around the 65psi fuel pressure range at full bore. Our pump should be able to handle that. I'd imagine the 340 should be okay, too.
I'd just hate to see you scrap what you have when what you have should handle the job.
Old Feb 15, 2011 | 12:59 PM
slowboy90's Avatar
wel;l thats why im asking if a walbro and a bosch will do ill keep the walbro and upgrade next year
Old Feb 15, 2011 | 01:01 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
what 1600cc injectors do you have?
Old Feb 15, 2011 | 01:05 PM
slowboy90's Avatar
i dont have them yet i currently have 1000cc and im going to idle the car on them again before i go dyno again with the new headgasket
VspecSiR
May 17, 2004 04:37 AM
speedyonez
Oct 23, 2003 12:17 PM
bey
Nov 19, 2002 06:58 AM
