Changing the Belts
Old Feb 7, 2011 | 10:35 AM
SeanK325's Avatar
Default Changing the Belts
Vehicle Info
- 98 Civic EX Coupe
- D16Y8
- Manual trans
- 186K Miles
- AC/PS
Searched around the forum but could only find a DIY on timing belts. Does anyone have diagrams on how to change the three serpentine belts? I'm not going to be able to do it. Got hurt in a car accident. So my bro is the unlucky one that I've volunteered.
Old Feb 7, 2011 | 10:59 AM
Former User's Avatar
Default Re: Changing the Belts
Going from memory:
Remove the splash guard and driver-side torque mount.
Loosen power steering pump mount bolts and remove PS belt.
Loosen center nut of A/C idler pulley and loosen belt by turning the idler pulley adjusting bolt. Remove A/C belt.
Loosen upper and lower alternator mount bolts. Remove alternator belt.
Reverse order for installation. You will need a pry bar (or something equivalent) to tighten the alternator and PS belts.
Old Feb 7, 2011 | 11:14 AM
Winlight's Avatar
if you remove the front drivers side tire and the plastic in there then you have better access,hope that helps your brother out some lol
Old Feb 7, 2011 | 03:12 PM
SeanK325's Avatar
thanks guys.
redm3turbo
Aug 18, 2015 04:59 PM
accord_2dr
Jan 13, 2013 07:31 PM
ShinyNewPenny
Aug 8, 2008 06:45 PM
auto-gs-king
Aug 19, 2002 07:57 PM
hybrider
Jul 28, 2002 08:05 PM
