Wire Tuck help please.
Ok so i started a wire tuck on my passenger side. I tuck the fuse box under the glove box.
i cut all the wires at once, instead of one at a time.
it was my first try, you live and you learn i guess.
i thought i could do it.):
I checked the fuse box, i wired everything up correctly, tested with a meter.
there is one ground that comes out of the fuse box. its black/ one silver dot. idk where it goes. there is also a ground the comes out of the 8 pin connector, not the 14 pin, and i can't figure out where it goes. its black/yellow.
also one vacuum plug has two ground coming out that are black/yellow. how do they wire up.
There are 4 ground wires in the headlight loom, do i run all for to my ground box, then to my headlights? cuz i think i ****ed that up.
also lastly, how do i wire up the radiator fan relay.
i deleted the A/C too, so that harness and two relays are gone.
NEED HALP PLZ
NEED HALP PLZ
k thats fantastic. but how do u think i can search 1100 pages? its just pictures and discussions of tucks that have already been finished.
wut i need is a wire diagram. ill post pics in a minute.
Clisped, just the man i wanted to see.
well look at my pics and maybe you can answer the couple questions i have. them, im picking up a Helms anywhere tho.
HEADLIGHT HARNESS:
I was able to wire up all the positives very easily
4 Grounds:
1 Thick Black
2 Black w/ Red Dots
1 Black w/ Silver Dots
8Pin connector i believe:
There is a ground wire coming out of here, where does it go?
to the ground box? Its Black/Yellow Stripe
Fuse box connection. this splits to the left. and goes over to where the battery fuse is.
As you can see I removed the A/C connection
There is a wire that comes out of the split, its Black w/ silver dots. where does it go?
4 Grounds:
1 Thick Black
2 Black w/ Red Dots
my questions were stated in the pictures.
thats wut i want HT to do.....
people have done tucks before. all they have to do is look at their harness.
well i found a helms wiring diagram, and i can read it for the most part. its slightly confusing.
grounds in the book dont seem to match my harness. also the grounds just say black, whereas in the harness they are slightly color coded
andyhoiho
May 29, 2004 07:58 AM
