JDM B16 alternator cross reference
Old Feb 7, 2011 | 08:18 AM
stegs's Avatar
Default JDM B16 alternator cross reference
According to CRXsi.com my JDM b16 has alternator 31100-PR3-013....that is only if my swapped b16 came from an SIR.....could have been from a JDM integra...???
Anyway, I think the above number is the same as a USDM 92 integra alt. Can anyone confirm.
More important, what options exist for replacement, the harness that plugs into my alt has a round green quarter sized plug with a clip and 4 female terminals inside like this:
_ _
Might be cool to get something with more amps.
Old Feb 7, 2011 | 08:20 AM
stackedhouse's Avatar
Default Re: JDM B16 alternator cross reference
yepp i used an integra one for mine
Old Feb 7, 2011 | 08:23 AM
stegs's Avatar
what amp is the teg alt? Does it matter what year of the DA or engine 1.7 or 1.8?
Also noticed all the teg alts are stocked out at advance, autozone, and crapboys....wonder why?
Old Feb 7, 2011 | 08:25 AM
theft24's Avatar
use a teg alt itl bolt and plug up, and if you got a obd2 alt laying around it will also work but you need to splice the obd2 plug into the engine harness
Old Feb 7, 2011 | 08:29 AM
stegs's Avatar
if it matters my b16A1 was originally a OBD0, although it has a OBD1 upgrade only to ECU and dizzy as well as sensors.
Old Feb 7, 2011 | 08:39 AM
theft24's Avatar
then use an 90-92 teg obd0 alt, i was just saying if you had an obd2 b series alt laying around to put it on and convert the plug over, thats what i did
Old Feb 7, 2011 | 08:52 AM
stegs's Avatar
Cool, thanks everyone!!!
Old Feb 7, 2011 | 09:11 AM
idk about amps i just took it in to my dads friends battery place and they matched it up to a 90 teg alt
Old Feb 7, 2011 | 11:32 AM
zrickety's Avatar
the d-series alternator is the same...i had one from a d15 dx and it was identical to my B16
Old Feb 7, 2011 | 12:10 PM
crx_si-r's Avatar
Any 90-95 b18 alternator will work with out mods.
Old Feb 7, 2011 | 12:16 PM
KINGVEM^^ED6's Avatar
clipsed has a d series one with his ls swap just swapped the pulley
slowestek
20
Sep 27, 2011 03:00 PM
EdSales
Jun 8, 2010 06:53 PM
B16ef8
Jan 27, 2003 12:53 PM
Stinkalope
Feb 23, 2002 10:05 AM
