2000 Civic EX 1.6L SOHC (D16Y8) PCV Valve Issue
Old Feb 7, 2011 | 07:28 AM
wilbur58's Avatar
Default 2000 Civic EX 1.6L SOHC (D16Y8) PCV Valve Issue
I have a problem with my 2000 civic ex 1.6 L SOHC
(D16Y8) 5MT.
I recently changed the pcv valve and it was brittle and ended up breaking off where it connects to the hose, so I could not remove the old one from the breather chamber, and it ended up inside the chamber. The engine runs fine. Is it going to create a problem to where the breather chamber has to be replaced?
Old Feb 7, 2011 | 07:58 AM
92lxsleeper's Avatar
Default Re: 2000 Civic EX 1.6L SOHC (D16Y8) PCV Valve Issue
unbolt the chamber from the block and it will fall out of the big hole on the back side lol. its only 1 10mm bolt
Old Feb 7, 2011 | 08:47 AM
wilbur58's Avatar
Thanks for the info. My particular breather chamber has 2 bolts.
Is it possible to remove it from under the back side of the engine, or do I have to remove the intake manifold & do it from above?:
johnnyk1726
Sep 8, 2013 04:14 AM
lilthomie
Apr 22, 2004 10:09 PM
