94 civic ITR motor HELP
Old Feb 6, 2011 | 09:08 PM
f22vtec1's Avatar
Default 94 civic ITR motor HELP
94 civic 98 ITR motor runs great no cel's but it will not idle for **** unless i pull the vacuum hose off the FPR ?
also i noticed when i put my hand over the throttle body it doesnt suck at all at idle ?
motor is all stock socketed p28 ecu
Old Feb 6, 2011 | 11:37 PM
f22vtec1's Avatar
Default Re: 94 civic ITR motor HELP
any ideas?
Old Feb 7, 2011 | 12:41 AM
f22vtec1's Avatar
well im off to bed... thought id give a bump before ! hope someone can shine some light on this issue for me :-)
Old Feb 7, 2011 | 08:07 AM
HAMOTORSPORTS's Avatar
Sounds like your Idle air control valve is not functioning.
Old Feb 7, 2011 | 08:41 AM
Former User's Avatar
The throttle plate should be slightly open at idle. If not, someone may have messed with the throttle stop screw, which should not be adjusted.
Old Feb 7, 2011 | 01:03 PM
f22vtec1's Avatar
the throttle screw is all ****ed cant even adjust it and i was thinking the iacv but wanted to be sure before i go spend money on one
Old Feb 7, 2011 | 03:32 PM
f22vtec1's Avatar
anymore ideas?
Old Feb 7, 2011 | 04:04 PM
Are you sure the IACV is wired properly? I'm assuming you used the EG wire harness and extended wires as necessary?
Old Feb 7, 2011 | 04:10 PM
f22vtec1's Avatar
all wiring was fine didnt have to extend anything ! everything is plugged in and i have no check engine lights ?
Old Feb 7, 2011 | 04:15 PM
blu_ej's Avatar
Did you just swap the motor in your car?
Old Feb 7, 2011 | 04:22 PM
f22vtec1's Avatar
it was in my buddys car ran great for a long time then it started to do that he couldnt figure it out he tried cleaning the iacv but didnt work and yes now its in my car
Old Feb 7, 2011 | 04:27 PM
blu_ej's Avatar
So I take it you are using everything from his car. ECU, dizzy, and engine harness.
Old Feb 7, 2011 | 04:43 PM
f22vtec1's Avatar
everything except wiring harness used my harness and just wired in vtec
Old Feb 7, 2011 | 04:46 PM
blu_ej's Avatar
I would try to bleed out the any possible air that could be in your cooling system then IACV. That is most likely the problem. If not try another ECU and or dizzy.
Old Feb 7, 2011 | 05:10 PM
f22vtec1's Avatar
tried a ecu didnt work.... i'll try bleeding the cooling system ! i have no access to another iacv or a distributor though :-(
Old Feb 9, 2011 | 05:57 PM
f22vtec1's Avatar
update ! so i unplug my iacv and it runs way worse so its working
iat is working and cts is working tps i havent checked yet
but im curious do throttle bodys go bad?
it does not suck air at all when idleing
Old Feb 9, 2011 | 11:16 PM
Check that the IACV wiring is good:
Check for continuity from the blue/yellow wire on the IACV plug to pin A9 at the ECU, and the yellow/black wire continuity to pin B1 and/or A25 and let us know what you find.
Also, just to note with Key on engine off - yellow/black should have +12 volts. If the yllow/black wire does not have +12 volts with KOEO, but has continuity to pin B1 and/or A25 then the IACV control within the ECU is fried.
Old Feb 10, 2011 | 12:00 AM
f22vtec1's Avatar
k thanks i will check later today and let u know
Old Feb 10, 2011 | 03:14 PM
f22vtec1's Avatar
k i tried 3 diff ecus so im sure the ecu is fine
all tests are checking out to be fine ! as well as i stated i have no check engine light !!!
car runs great just wont idle without a vacuum line removed !
Old Feb 10, 2011 | 04:03 PM
f22vtec1's Avatar
any other ideas guys? or tips ? im racking my brain here
Old Feb 10, 2011 | 05:10 PM
Is the screw on the TOP of the throttle body screwed all the way in maybe???
Old Feb 10, 2011 | 07:07 PM
f22vtec1's Avatar
i believe so and its all ****ed up i cant adjust it at all
Old Feb 10, 2011 | 07:27 PM
myjdmsucks's Avatar
Is the EVAP purge solenoid nipple on the Intake manifold capped off or plugged in?
I remember my car idled like crap until i capped that.
sucks about your throttle screw
Old Feb 10, 2011 | 07:41 PM
f22vtec1's Avatar
where the heck is that at on a type r motor?
Old Feb 11, 2011 | 01:27 PM
f22vtec1's Avatar
still no ideas ?
