1991 Honda Accord LX Alternator
Your alternator is doing something, or you would never get a reading more than 12 volts. I would suggest taking the alternator reading on the clamps, because if your battery posts are corroded you will not get a true reading. Cleaning the battery posts, and making sure connection is tight is always a good place to start troubleshooting. Alternator reading should be at least 14V. Voltage alone cannot troubleshoot alternator problem, but if you are not getting at least 14V it probably has a problem.
Sounds like the diods or you resistor, or possibly both, are fried. I had the same issue with mine a while back. Do you have an upgraded sound system in your car?
BobRodgers3
Sep 22, 2012 06:40 PM
hondaracin24
May 30, 2005 08:17 PM
12, 1991, 2002, 91, accord, accordlx, alternator, alternators, charging, civic, honda, lx, problem, sound, troubleshooting
