Broken 89 Civic SI Seat pan - what will interchange?
Old Feb 6, 2011 | 04:56 PM
don foreman's Avatar
Default Broken 89 Civic SI Seat pan - what will interchange?
My stock 89 Civic SI Seat pan has broken badly. The previous owner made it worse with a few attempts at welding with the heat set up too high. So my best bet is finding another pan. I have searched for the replacement info and it depends on who's post you read. I read 88-89 are the same, I read only 89, then I found one that said all 89-91. I'm not sure if four door seat pans are the same as the hatches?
The only thing they seem to agree on is that CRX will not interchange with Civic. Has anyone actually replaced a seat broken pan in a 89 HB and if so what was the donor?
Old Feb 6, 2011 | 07:19 PM
jdmboyef9's Avatar
Default Re: Broken 89 Civic SI Seat pan - what will interchange?
From what I have read, 88-89 civic pans are the same. Crx will not work and neither will 90-91. Snag some scrap dx seats from a junk yard and you should be good.
Old Feb 6, 2011 | 10:23 PM
EE2bitsk's Avatar
all the sedan seat pans are the same, from 88-91.
im not totally sure on the hatch's, but im assuming they are.
do not use crx or wagon ones, all the rail mounts will be off.
Old Feb 6, 2011 | 11:10 PM
efjones9's Avatar
How was it broken in the 1st place? Jus curious lol. U will need 88-89 seat pan. 90-91 are different. And if u have a hatch it can only fit a hatch and sedan I believe. But for sure u can't use a crx pan
Old Feb 7, 2011 | 08:02 AM
EE2bitsk's Avatar
i know for a fact that the 88-89 sedan seat pans are the same as 90-91's. im pretty sure the hatch's are the same as well, id have to check at a yard to confirm that though.
Old Feb 7, 2011 | 11:35 AM
jdmboyef9's Avatar
You are 100% wrong. 88-89 had different rails. That is why the jdm seats only bolt into 88-89 hb's
The rails are wider on 90-91's and don't try to argue this with me because this has been a long time know fact. Search seat pan swap for 88-89/90-91
crx rails are also different and won't bolt into a hatch. 88 crx is one year, 89 crx is another, 90-91 crx is different too.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/seat-pan-swap-90-91-si-seats-88-hb-1062869/
Research before posting wrong info. The original poster needs to get 88-89 civic pans ONLY!!! if he ever wants to bolt them back into his car.
This should be easy to find because the 88-89 seats wear out more than the 90-91 therefore a lot more junk seats at the yards
Old Feb 8, 2011 | 09:44 AM
EE2bitsk's Avatar
https://honda-tech.com/forums/showthread.php?t=1062869
i was referring to the 88-89 sedan pans and 90-91 sedan pans, not the crx ones.
im guessing the pan on the civic si seat is different than the dx model hatchs, and the sedans though..
Old Feb 8, 2011 | 10:11 AM
jdmboyef9's Avatar
the pans for the 88-89 civic dx/std/si hb use the same lower pan. The Si has a different upper but since the pans are the same it bolts up for the correct year
Old Feb 8, 2011 | 10:30 AM
EE2bitsk's Avatar
word thanks for clarifying.
Old Feb 8, 2011 | 11:20 AM
jdmboyef9's Avatar
Hopefully this can help to illustrate for the 88-89 hb, one pan two cusions
http://www.hondapartscheap.com/south...t=0&quantity=0
VtecNotRequired
Sep 22, 2010 07:26 PM
gunnerman
Dec 16, 2008 09:43 AM
ridgeapd
Dec 7, 2007 08:50 AM
Shaguar47
17
Mar 22, 2006 08:57 AM
serious
Feb 24, 2003 08:44 AM
