How do you know if ur brake rotors are warped ?
Old Sep 25, 2002 | 05:27 AM
RacerXintegra2k's Avatar
Default How do you know if ur brake rotors are warped ?
i read the post about the brake rotors being covered by warrenty. was wondering how do you diagnose this ? like how do you know when ur rotors are warped ? i want to find out before my warrenty runs out
Old Sep 25, 2002 | 05:37 AM
Rory Breaker's Avatar
Default Re: How do you know if ur brake rotors are warped ? (RacerXintegra2k)
If your steering wheel vibrates under braking, chances are your rotors are warped.
And I dont think a warranty would cover it, unless they were prematurely warped...like if you had them replaced at 25k, and at 29k they started vibrating again. Its a wear item, so it would have to be proven defective.
Old Sep 25, 2002 | 05:40 AM
Default Re: How do you know if ur brake rotors are warped ? (newgsrdriver)
like at what speed .. they start shaking if say i brake from ... 100+ down ? thats not rotor warp is it .. my car 20k miles
Old Sep 25, 2002 | 06:17 AM
billabongrob's Avatar
I've been wondering the same thing except mine shakes whenever I brake
Old Sep 25, 2002 | 09:25 AM
EL Vap133's Avatar
Your rotors can warp at anytime, does your steering wheel shake when you step on the brake? Just get some performance rotors...
Old Sep 25, 2002 | 11:59 AM
GSRaCeRbOI's Avatar
when my rotors were warped when i stepped on the brake there was a vibration on both the brake pedal and the steering wheel... on the pedal it would kinda be like an up/down motion as I stepped on/applied steady pressure to the brake pedal...
on the steering wheel its a quick left/right/left/right (cycle continues) motion of the steering wheel as the brakes are applied...
I changed my pads and rotors are the same time.. got Brembo OE Blanks and Hawp HPs.. got it all from http://www.collettimotorsports.com (click on specials) $28/rotor + $10/rotor shipping for the fronts... rears are $20/rotor $10/ea ship.. front pads are like $80 and rears are like $50 or 60.. I forget..
EDIT: oh yeah if you need instructions/the procedure.. check this link out..
http://www.bseries.net/html/garage/brakes.php
[Modified by GSRaCeRbOI, 1:00 PM 9/25/2002]
Old Sep 25, 2002 | 03:01 PM
DC2_Integra's Avatar
Default Re: How do you know if ur brake rotors are warped ? (GSRaCeRbOI)
i was wondering the same thing, but in my case, the vibrations only comes in when im braking driving downhill. but other than that, when im braking on a level road its fine. So is this my rotors that are warped or is it my ABS kicking in?
Old Sep 25, 2002 | 04:36 PM
Mase's Avatar
Default Re: How do you know if ur brake rotors are warped ? (DC2_Integra)
as most of you may know, but ill say it anyways, you can warp your rotors in a heart beat by the lug nuts not being torqued properly, always use a torque wrench, and tighten them down to 80 ft/lbs .......
Old Sep 25, 2002 | 05:03 PM
GSRaCeRbOI's Avatar
Default Re: How do you know if ur brake rotors are warped ? (CDooMe2)
other than this... they can also get warped by washing your car after a hard run/driving..when you spray the cold water on the hot rotor... also sitting on the brakes/in traffic after a hard run.. the part that the caliper and pads sits over the rotor is hotter/loses heat slower than the rest of the rotor... also watch out for those tire shop/mechnic guys who go crazy w/ the impact wrench...
josiah965
12
Nov 13, 2009 05:00 PM
WalkerGSR1
Suspension & Brakes
Aug 13, 2006 02:36 PM
james p.
13
Jun 5, 2005 08:17 AM
ThaSpitefulWun
Jul 10, 2004 01:12 PM
speedehatch
Dec 3, 2003 11:57 AM
