RULES!! for Hot Rod/Quick Class (Calling all Racers)!
Old Sep 25, 2002 | 04:59 AM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
Default RULES!! for Hot Rod/Quick Class (Calling all Racers)!
I would like to know some stuff that you can do to your car.
What body panels can we run with and not run with.
etc...
1)Does the shatterproof glass have to be a certain thickness?
2)Can we run without the stock sideskirts?
3) Do we need a dashboard in this class
4) What can be cut and what can't be cut.
5) Any good websites or companies you'll use for you'll products.
6) Which type of material do you'll use to cover what you'll cut from the rear floor and rear side, door panels, etc..?(Aluminum, anything lighter)
Thankz for all you'll help. IDRC/NHRA do not clarify specificallly what can be done and can't be done.
Old Sep 25, 2002 | 08:01 AM
b18bturbo's Avatar
Default Re: RULES!! for Hot Rod/Quick Class (Calling all Racers)! (Civicdrgrcr)
etc...
1. MR 10 lexan best you can buy works great
2. You can run without stock sideskirts but becarfuel sine you want a most aerodynamic car so dont do something stupid to disrupt theair.
3. You dont need a dashbaord but just make the car look better if you do.
4. You can remove the front parts such as front cross member cutt the fenders and you can mount a front mount fiberglass or cabron body.
5. Mb products has everything you neeed.
6. Aluminum is cheeapest carbon is the lightest.
Old Sep 25, 2002 | 08:38 AM
Default Re: RULES!! for Hot Rod/Quick Class (b18bturbo)
Who sells carbon? LIke to cover the rear parts that have been cut and panels.
Old Sep 25, 2002 | 10:35 AM
hondaswaper's Avatar
Default Re: RULES!! for Hot Rod/Quick Class (Civicdrgrcr)
the minimum thickness for the lexan is 1/8th in. and the windshield must have a rod down the middle to support it
Old Sep 25, 2002 | 12:15 PM
Default Re: RULES!! for Hot Rod/Quick Class (hondaswaper)
Yeah I found out already. Carbon like in CF who sells it like that ***** expensive.
accordmark88
Dec 31, 2011 12:17 AM
Civic89stdB16
Jan 21, 2010 03:25 AM
Swansen
Paint and Body
Dec 13, 2008 07:06 AM
Prudz_lude
Paint and Body
Nov 26, 2008 11:21 AM
SDmark
Nov 12, 2008 08:54 PM
