Transmission & Drivetrain Gearboxes, Differentials, Clutches
shifting problem going into 3rd and down shifting
Old Feb 6, 2011 | 09:33 AM
brooklynEG's Avatar
Default shifting problem going into 3rd and down shifting
Hey ht I have an Eg 93 with a 98 Ls motor and tranny .. I just got it running plates and all monday .. I rehad to also rebuild the transmission .. while putting it back together my step father mentioned that my shifter linkage looks like its from a d series .. its hard to down shift while driving also its hard to get the tranny into 3rd while driving , plus you need to use some force to shift .. I know nuthing canbe wrong with. The tranny internals so my only guess is its because I might have d series shifter linkage ... please give me some feed back asap if these are signs of linkage problems! ( also the car does not grind at all that what makes me think it is the linkage )
Old Feb 8, 2011 | 08:13 AM
95teggyfrankens's Avatar
Default Re: shifting problem going into 3rd and down shifting
im having the same problem but shfting into second is the hardest gear to get into. i just did a b16 swap and used my ls tranny, that worked perfectly with my ls motor. i bleed the clutch, made sure i have the perfect amount of fluid, and pulled the starter and retorqued my pressure plate bolts.... im at a loss. btw im using the same linkage i was using before, that worked perfectly.
Old Feb 9, 2011 | 05:31 PM
brooklynEG's Avatar
bump for any ideas .. i did some talking with local and they said they think my problem could be traced to the slave cyclinder because the shifting into 3rd is a now and then problem with no grinding and my local mechanic said that if itwas linkage it would be like that all the time so i im try to bleed mines over .. input on this would help
Old Feb 9, 2011 | 05:33 PM
brooklynEG's Avatar
ima try what you mentioned also pulling the starter and retorque the bolts for the pressure plates ... but would that really make a difference ??
brooklynEG
14
Feb 5, 2011 05:44 AM
blkcivic310
Jul 21, 2010 08:19 PM
aznintegraracuh
Aug 31, 2007 04:08 PM
RMX_EF9
37
Jun 18, 2007 02:20 PM
743power
17
Oct 25, 2003 06:04 AM
