CA 92 Civic CX fully built b20v clean title bar'd Alaniz comp head
Im selling my 1992 Civic CX that holds a clean title and is ref'd for a 1.8 Acura Integra motor.The car is located in Sacramento CA I had the whole car sprayed inside and out 2000 ITR black (3 months ago), payed $1300 for body work at a well known body shop in Rancho Cordova by the name of Triple F Design.Im asking $7000 my number is 916-384-8734 The car is smogged and registered.
I have over 30 reciepts and several boxes from all the parts to go with the car. I have rear gray interior panels with speaker grills rear gray Gsr leathers seats.
*Tuned on hondata s300 at DynoSpotRacing in Sanjose by Lawrence.It made 218hp 154lbs of torque
94 GSR Head Alaniz Competition headwork
*Skunk2 dual valve springs
*Crower titanium retainers
*New stock GSR valves
*Blox Pro 1 cams Degreed
*1st Gen Skunk2 manifold
* Blox 68 mm port matched to ITM
*RC 310 injectors
*Tri Y headers (with 2.5 blox collector ran back to open Dyno Max muffler with no cat)
B20Z2 Block
*CP 11.5.1 pistons
*Eagle Rods
*ACL Race bearings
*All new oem oil pick up and pan
*Z10 block girdle
*Moroso oil pan with new oem oil pan gasket
*Ctr crank pulley
*Brand "NEW" Golden Eagle LS-V KIT
*NEW NAPA Alternator and Starter
*00 SI B16 transmission (purchased from HAP i have reciept no grinds at all shifts like butter 90,000 miles on it.)
*10 lbs XTD flywheel Exedy street clutch "NEW"
*JDM Head lights with city lights, JDM corners, JDM taillights
*New oem fenders hood and rear bumper, and EX lip have reciept from honda dealer. Jdm black faced gauge cluster
*Autopower 4pt roll cage bolted down
*Delsol Red stripe seats on DC rails
*Rota track R's 16 95% tread on all 4 kumho tires
*Blox full coilovers/Blox lug nuts/Blox rear lower contorl arms
*DC rear tie bar
*GSR front and rear disk brakes front have extended wheel studs, I have 8 more extended wheel studs for the rear that have not been installed yet. Gsr fornt sway bar
*Clifford Pager alarm
*Alpine head unit
*JL AUDIO XR front componets and JL 4in rear speaker
*JL AUDIO 300/4 amp
BEFORE
AFTER
*RC 310 injectors
B20Z2 Block
*CP 11.5.1 pistons
*Eagle Rods
*ACL Race bearings
*Z10 block girdle
*Ctr crank pulley
*DC rear tie bar
*Alpine head unit
*JL AUDIO 300/4 amp
BEFORE
AFTER
i think that motor can make way more power bro dude!!!!!! had the same set up with out rods and and such just pistons and made 240 on 91 bro! bump!!!!!!
