prelude engine sway
I have a 1996 prelude can i take out my h22 and put in a f22 soch motor in this the reason im doing this is that the class i might be racing in cant have more than 150horsepower stock will the wiring harness hook up and will it bolt to the transmission it is a 5 speed
sure you can .. the harnesses are very similar between the two .. You can use your current h22 harness on the f22 motor, you'll just have unused plugs for the VTEC and knock sensor .. just don't forget to use the f22 ecu as well
vtecpower3088
Nov 6, 2008 04:09 PM
