Who makes aftermarket hatch struts?
Old Feb 5, 2011 | 10:52 AM
NotNew's Avatar
Default Who makes aftermarket hatch struts?
My trunk/hatch/gate hits me on the head from time to time, I did a bit of searching but I couldn't find any info other then stock replacement stuff. Is there a company that make nicer struts that look a little better then the black stockers? Like the Tein hood support struts?
Old Feb 5, 2011 | 11:09 AM
kaiba's Avatar
Default Re: Who makes aftermarket hatch struts?
Buy the aftermarket one from your local autoparts store. They usually carry strongarm or stabilus. You can alway sand it down and repaint it. Then use heat gun to cure it.
Old Feb 5, 2011 | 03:20 PM
NotNew's Avatar
Originally Posted by kaiba
Buy the aftermarket one from your local autoparts store. They usually carry strongarm or stabilus. You can always sand it down and repaint it. Then use heat gun to cure it.
thats not a bad idea.. thanks
Old Feb 5, 2011 | 06:37 PM
KINGVEM^^ED6's Avatar
i got a lil c clamp those struts are like 30a piece
Old Feb 5, 2011 | 06:57 PM
miguey310's Avatar
or just go to the junk yard and get some from there
Old Feb 6, 2011 | 01:51 PM
zsiya's Avatar
Replaced mine with ones from Advance. Amazing what a relief it is knowing you won't be knocked out by a falling hatch.
Old Feb 6, 2011 | 03:14 PM
asianflava's Avatar
That's if you find a decent pair. Those things go out all the time. I've noticed that the ones on the CRX don't last nearly as long as the hatchback. Just buy a pair from Autozone or Advance.
Old Feb 7, 2011 | 12:32 PM
gringo7718's Avatar
I drilled a hole in the shaft and use a pin to hold up the hatch. Best part is that its free.
sinepome
Oct 4, 2008 10:33 PM
hotwater
Jul 29, 2008 09:14 AM
jxhxb
Nov 24, 2007 11:05 PM
crxsleeper210
Oct 25, 2007 03:11 PM
xJ.SLOTHx
Jan 13, 2004 07:11 PM
