Suspension & Brakes Theory, alignment, spring rates....
will koni reds from 93 si fit 95 si?
Old Feb 5, 2011 | 08:47 AM
boosted95si's Avatar
Default will koni reds from 93 si fit 95 si?
i thougt the 93 si and 95 si coupes would have the excat same rear end set up... i was wrong. i have a brake kit and koni reds id like to use again. but the swing arms and stabilizers are different.. should i just change them to the 93 or can i use what i have,...
Old Feb 5, 2011 | 06:18 PM
98civdx's Avatar
Master Detailer
Default Re: will koni reds from 93 si fit 95 si?
They will work, the shocks should be the be the same.
I assume one has rear disk the other does not? And one has a rear sway bar and the other does not?
Old Feb 6, 2011 | 04:34 PM
yea my old car had the conversion 93, then i wrote it off. all i could get off of it were the rotors, calipers and shocks from the rear. all i did was throw my rims on the other shell and rip it. took a quick look and they are different. i was wondering if it was just design differences or if the shock set up was different. also the hub looks different so i dont know if my gsr brake will fit.. hopfully they will
Old Feb 6, 2011 | 04:55 PM
D16SohcVtec's Avatar
It works fine, you can even use them on 96-2000 Civics if you had the spacers for the rear.
Old Feb 6, 2011 | 05:54 PM
98civdx's Avatar
Master Detailer
your kind of correct, but kind of wrong.
You are correct he can use 96-00 on his car, however, where you are wrong is need spacers.
He would actually need to shave his bushings for the fork to fit, if he were using 92-95 on 96-00 he would need spacers.
92-95 have wider forks,and bushings then 96-00.
Old Feb 6, 2011 | 11:55 PM
94GSRlbc's Avatar
yup 92-95 civics and 94-01 all the same
Old Feb 7, 2011 | 04:59 AM
kyden's Avatar
you read him wrong. he said you can use them on a 96-00.
Old Feb 7, 2011 | 08:54 AM
98civdx's Avatar
Master Detailer
My fault.
BoostinEJ1
Feb 21, 2005 02:19 PM
89 pos
Sep 22, 2004 01:13 PM
Vp Special K
Oct 16, 2002 09:56 PM
