driver door locking issues?
the inside of door when i try to lock locks other 3 doors but not drivers then when i get out it always takes me like a few minutes of wiggling key in and out to get it to lock or unlock...
common issue? anyone know how to fix?
You may need to lubricate the lock cylinder. There's a special lubricant for locks, which you can even buy at Walmart.
The problem with the driver's door not locking may be a bad actuator, assuming that the door smoothly locks manually (mechanical versus electrical problem).
I have a similar problem. My doors will lock fine when the car is on by pressing the inner door lock lever. However when the car is off, the rod is difficult to push down. Doesn't like to be locked from the outside either.
square_1
13
Oct 13, 2010 07:11 AM
gezulu
Honda Civic (2001 - 2005)
Sep 13, 2008 04:02 PM
