Lowering spring question
Old Feb 4, 2011 | 01:00 PM
NjzFinestG's Avatar
Default Lowering spring question
hey i have a 97 accord coupe. will lowering springs from a 98 civic fit?
Old Feb 4, 2011 | 05:08 PM
wolfy47's Avatar
Default Re: Lowering spring question
search
Old Feb 4, 2011 | 05:50 PM
Brownjd's Avatar
even if they would "fit" you can't use them. the spring rates are not going to be stiff enough to hold up for our much heavier accords. you definately do not want to put civic springs on your accord.
Old Feb 4, 2011 | 07:23 PM
nus_dogg's Avatar
I won't work.
Old Feb 5, 2011 | 08:53 AM
stare dad's Avatar
If this is a serious question, you should probably avoid modifying any major components on your car before you hurt something (or someone)
Old Feb 5, 2011 | 07:52 PM
specialone70's Avatar
this is a rather queer question, and i dont think anybody will be able to answer it for you. you might just have to compare them and try it out yourself
good luck tho!
Old Feb 7, 2011 | 12:15 AM
bianchadsuchon
Guest
Posts: n/a
this sounds stupid i know but ur better off cutting ur springs lol
redb16coupe
May 19, 2008 06:55 AM
Diaz90
Honda Civic (2006 - 2015)
May 10, 2008 08:16 PM
poetikrime
Mar 6, 2008 08:36 AM
FLiPFeLLaH
Jan 27, 2006 08:19 PM
91SIvic
Feb 2, 2003 06:46 PM
