4 sped clutch work on 5 speed?
Old Feb 4, 2011 | 08:56 AM
Tmfw's Avatar
Default 4 sped clutch work on 5 speed?
Have a D16a6 that blew that had a (1991)4 speed std engine mounted to it,Will the 4 speed clutch fit a (1989) D15 5 speed trans?
Old Feb 4, 2011 | 09:02 AM
jason saizan's Avatar
Default Re: 4 sped clutch work on 5 speed?
man i never tried that but 90% sure yeah souldnt b a prob
Old Feb 4, 2011 | 09:11 AM
Tmfw's Avatar
Ok cause Someone said that the 88-89 had different teeth or what ever than the 90-91 on the shaft
Old Feb 4, 2011 | 09:13 AM
4drEF's Avatar
Keyboard Humorist
The 88 would not work with 89~91.
That's the only issue.
Old Feb 4, 2011 | 09:15 AM
Tmfw's Avatar
Ok that might be what it is forsome reason i was thinking it was an 89 i'll ask the guy again what year its out of
Old Feb 4, 2011 | 09:55 AM
Tmfw's Avatar
He said its an 89 but someone said to count the splines
Old Feb 4, 2011 | 10:14 AM
4drEF's Avatar
Keyboard Humorist
Counting the splines is an easy way to double check to make certain it's compatible.
You can even use EG+ D-series hydro clutches, but must use cable throw out bearing.
Old Feb 4, 2011 | 10:17 AM
Tmfw's Avatar
interesting..thanks for the help
90civic1.5
31
Jan 9, 2011 11:48 PM
KoDKingVegeta
Apr 23, 2009 04:50 PM
dkrex001
Oct 23, 2006 06:40 PM
RenoRacing
Dec 21, 2001 07:06 AM
