GSR ECU
Old Feb 4, 2011 | 07:05 AM
DA STRIKER's Avatar
Default GSR ECU
I just got a gsr mototr but I don't have the ecu.Will any b motor ecu work just like the gsr ecu?
Old Feb 4, 2011 | 07:29 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Default Re: GSR ECU
no
Old Feb 4, 2011 | 09:25 AM
mouab18c1's Avatar
Default Re: GSR ECU
If you are running a complete stock setup. Then get the stock gsr ecu.
Old Feb 4, 2011 | 11:22 AM
1998GsRIntegra's Avatar
Default Re: GSR ECU
Just a gsr ecu will support the secondaries.
Old Feb 4, 2011 | 11:26 AM
JdmTypeRdc2's Avatar
Default Re: GSR ECU
You can always remove the secondaries from the GSR manifold and use a different ECU if you want, such as a p73, or convert to OBD1 for use with a p28.
It wont run as it should, but nevertheless, it can be used.
Old Feb 4, 2011 | 11:34 AM
2LEM1's Avatar
I like to party
Community Builder
Default Re: GSR ECU
He said "any b motor" ecu which leaves out the P28. Doubtful he has a P73 either. I'm assuming he is going to try a P74/p75 which won't work very well at all.
Just use the P72 OP
Old Feb 4, 2011 | 03:49 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: GSR ECU
Only a P72 will work the IAB system. The year also matters.
ef2hondaboi
Jun 23, 2009 04:33 PM
tmar253
Nov 28, 2006 09:39 PM
wildcard69
May 5, 2005 08:47 AM
TKL
Apr 28, 2004 08:53 AM
cooukiemonster
Dec 16, 2003 04:09 PM
