Who runs their alternator on a Full Drag Car?
Old Sep 24, 2002 | 11:12 PM
AbaZ's Avatar
Default Who runs their alternator on a Full Drag Car?
As the Topic States? Anyone....?
I really dont have a need for it, since I have a Gel Cell Battery (marine) that can easily do 40 passes No problem, then a recharge. Just curious if anyone has done it or not.
Jeff
Old Sep 25, 2002 | 01:33 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Who runs their alternator on a Full Drag Car? (AbaZ)
Viren runs an alternator. I know becuase I always had to change that POS bitch belt and it got old after a while. Get a turbostart battery.
art
Old Sep 25, 2002 | 05:38 AM
tony1's Avatar
Default Re: Who runs their alternator on a Full Drag Car? (Arturbo)
You are gonna need to run it unless you run a 16 volt battery. Even though your's won't loose it's charge for a while, it will only put out 12.5 volts. The car needs at least 13.5-14 volts to run good, which is what the alternator does.
Old Sep 25, 2002 | 05:56 AM
CHEETAH's Avatar
I run an alternator on CHEETAH because no battery with reasonable wieght can supply enough juice to my 7AL.
Greg
Old Sep 25, 2002 | 07:18 AM
dohcsideSi's Avatar
Default Re: Who runs their alternator on a Full Drag Car? (CHEETAH)
Greg
i have a 16v battery i got from summit.....i was going to upgade to the 7al....no go?? i would hate to have to put an alternator back on....i would rather stick w/ a 6al
Old Sep 25, 2002 | 07:27 AM
fortynineR's Avatar
Default Re: Who runs their alternator on a Full Drag Car? (dohcsideSi)
i have a digital 6... and i was just wondering if i can run without the alternator?... how bout running other stuff like the tach?
Old Sep 25, 2002 | 07:38 AM
CHEETAH's Avatar
the 6 series ignitions only burn a little current, the 7 series burns a lot, I use because I ran lil over 17:1 compression.
Greg
Old Sep 25, 2002 | 07:52 AM
dohcsideSi's Avatar
DAMN!! on race gas>??
Old Sep 25, 2002 | 07:58 AM
b18bturbo's Avatar
i also made the switch toe the 16 volt setup becuz i was itred of breaking alternator belts and doing stupid stuff voltage now stay at constat 14 volts still need a little more juice though. That with a new msd 10 igntion box which ungodly amount of spark.
Old Sep 25, 2002 | 08:19 AM
AbaZ's Avatar
Now running a 16v system will the rest of my stuff work? MSD/Gauges blah blah..? I guess its not really a big deal to take it out, I could leave it in their, I was just thinking if their would be any type of benefit to take it out.. I am only running a 6 BTM box and a few gauges. I couldnt see a real problem if it dropped anything below 12 volts..
Jeff Frank
Old Sep 25, 2002 | 09:12 AM
martini's Avatar
haha, I doubt it was pump gas.
I run an alternator. But admitedly, my car isn't as "full drag" as others. If it gets to the point where I can't figure out where to get more power from, then I'll consider taking the alt out. Until then, it stays, because I don't want to **** with it.
Old Sep 25, 2002 | 09:16 AM
fortynineR's Avatar
What do u think of the vip battery sold by performancedistributors.com?... it is only 11 lbs and has 18volts... made to run without the alternator....im just wondering if i can use this and also use my stock tach with a digital 6?.....
Old Sep 25, 2002 | 09:46 AM
allmotor92civic's Avatar
Default Re: Who runs their alternator on a Full Drag Car? (fortynineR)
im still running an alternater. we tryed running without it and ran into nothin but problems
Old Sep 25, 2002 | 11:17 AM
CHEETAH's Avatar
Default Re: Who runs their alternator on a Full Drag Car? (Whiteguyontop)
Whtas most likely to win WRX or Skyline GTR?
I've driven both, WRX HEAVILY modified, the GTR was stock except triple disc clutch ... GTR feels like a dog cause the damn thing is really heavy, but the top end pulls ... JESUS !!!
No chance the WRX winning unless you shoot it with a 200 shot and 40psi boost LOL
Greg
Old Sep 25, 2002 | 01:12 PM
dohcsideSi's Avatar
Default Re: Who runs their alternator on a Full Drag Car? (martini)
haha, I doubt it was pump gas. .
i meant race gas or methanol
Old Sep 25, 2002 | 01:37 PM
hondaswaper's Avatar
we run a 16v battery with no alternator and a MSD digital 7.......
Old Sep 27, 2002 | 06:26 AM
CHEETAH's Avatar
Default Re: Who runs their alternator on a Full Drag Car? (hondaswaper)
the digital series are very efficient on current usage ... since I have the 7AL box and a PAXTON regulator and electric h20 pump, a battery wont keep all that supplied even on full charge. For the alternator pulley, I used a bigger one so high RPM won;t kill it.
Greg
Old Sep 27, 2002 | 07:42 AM
fortynineR's Avatar
how many volts is required to run the fuel pump? electric water pump, and all other little accesories and gauges?... i remember erics racing had 2 batteries... he used an rc battery to run some of the accesories.... but im not sure if thats enough?....
Old Sep 27, 2002 | 09:35 AM
CHEETAH's Avatar
I never did a check on mine, however in a few cars I've datalogged the voltage throughout a run and it does go down as low as 11.9 to 12.1 volts (starts out at around 13.8 or even 14.1 when there is no alternator and the motor at high RPM in high gear.
greg
Old Sep 27, 2002 | 02:27 PM
Elite Hatch's Avatar
No alternator is the way to go
Old Sep 27, 2002 | 03:47 PM
ninesecrx's Avatar
Default Re: Who runs their alternator on a Full Drag Car? (Elite Hatch)
I run a alt. on our car to keep the current in it. If it drops, cars gonna crap out. Plus I dont want to have to jump start and recharge a battery every round. Plenty of otehr stuff to worry about. I have never shred a belt or thrown a belt reving the car till 10,000rpm....knock on wood because I know others have this problem...Mike
Old Sep 27, 2002 | 10:01 PM
tony1's Avatar
Default Re: Who runs their alternator on a Full Drag Car? (ninesecrx)
When you switch to methanol you might want to look into the 16v. If you look at the output of the weldon pumps it is alot more at 16v than at 14v. or realistically 12.5 with the alternator under load and 14.5 with the 16v. It's hard enough to get enough methanol to these motors, don't need any more challenges!
Old Sep 28, 2002 | 02:41 AM
SEFIxCivic's Avatar
Default Re: Who runs their alternator on a Full Drag Car? (tony1)
to swtich to 16 volt... all you need is the battery? or is there more to it? thanks
Old Sep 28, 2002 | 05:44 AM
tony1's Avatar
Default Re: Who runs their alternator on a Full Drag Car? (SEFI8LOxCivic)
All you gotta do it change the battery. You will also have to buy the turbostart battery charger. The battery is about 45lbs which is really close to the weight of an optima or something but you lose the weight of the alternator and brackets. You voltage shouldn't ever drop below 14.5v and should be around 15.5 to 16v under light load!!
Old Sep 28, 2002 | 10:10 AM
b18bturbo's Avatar
Hey tony.. did you batter come with the sulfuic acid.. to fill inside of it.
