Suspension & Brakes Theory, alignment, spring rates....
Will Oem balljoints work with skunk2/blox upper control arm?
Old Feb 4, 2011 | 06:13 AM
namewasdallas's Avatar
Default Will Oem balljoints work with skunk2/blox upper control arm?
Will Oem ball joints work with skunk2/blox upper control arms??
I can only use OEM ball joints because the one's that come with the aftermarket skunk2/blox are prone to crap out in a few months in the HARSE enviorment of upper NY. I like the aftermarket UCA because you can get a awesome allignment over stock UCA's.
Anyone have any idea im trying to figure out if i got to get all OEM ball joint/UCA or i can mix the 2 its going on a 98 coupe with civic type R suspenssion
Old Feb 4, 2011 | 06:23 AM
speedooo's Avatar
Default Re: Will Oem balljoints work with skunk2/blox upper control arm?
No, the skunk2 joints clearly have plates and locking bolts and oem joints do not.
Old Feb 4, 2011 | 06:37 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
What is your definition of an "awesome alignment"? Unless you're super slammed, you can safely use OEM upper control arms and just have the toe adjusted when the car is aligned, and your tires will be fine.
Toe wears tires quickly, NOT negative camber.
Old Feb 5, 2011 | 04:01 PM
thanks, im just going to stick with OEM UCA and Ball joints.
parki59
Suspension & Brakes
19
May 5, 2010 08:09 AM
offcamber
49
Apr 10, 2010 09:05 AM
gwiffer
Suspension & Brakes
Feb 14, 2010 08:50 PM
Pondus
Suspension & Brakes
Mar 17, 2009 08:51 AM
tomek5x
Suspension & Brakes
Mar 13, 2008 05:38 PM
