90 crx hf wire harness in 89 dx..
since my last topic was old already, and no one wants to post in their i wanted to try to make a new thread... if you guys knew, i had to swap out my 90 hf crx dash, and engine harness into my 89 crx... problem here is... i replaced everything.. but theirs something wrong with connections here... my blinkers dont work, the tone you hear from the sound on your headliner(above your rear view mirror) thing keeps going... my clauster whenever i use the left turn signal, my temp gauge shoots up... and right one.. it tries to blink... but it does not ...
so wat im trying to say here.. can i possibly rewire the hf wiring components to the spare dx dash harness i got?
i keep poping num 1 fuse(turn signal)
who gots a nice noob understandable wire diagram here?
PLEASE AND THANK YOU!!
Just like disconnecting your negative cable from the battery - nothing works then.
ah k... ill check the grounds out then... would u have any idea why theirs like multiple ground wires that goesinto one small relay in the engine bay by the headlights?
it bend a wild for me but i have a new wark and need help on. i have a after marget autochips powermax that go on the ecu and need to know how to put it on or a diagrams would help. thanks jpullen
i fix couple tweaks, but not theirs more >.<
my rpm tach dont work no matter what i do
temp gauge also dont work
gas gauge dont either
as well as when i step on the brakes it works... but it turns on the gauge lights, clock lights, and corner lights >.<
the annoying door beep stays on too now >.<
wtf car runs fine tho :S
what would cause my brake lights to cross wires with the dash lights and corner lights?
when i use blinkers it stays a solid amber... doesnt blink ??
CRXREFIC
Jan 24, 2011 10:00 PM
88EFrex
May 11, 2010 08:51 AM
