15mm Spacers trouble....
So I have sportmax 501's which have a bolt pattern of 4x100 and 114.3. I just installed a rear camber kit and was gonna purchase a 15mm spacer for the rear so the wheels are at a 0 offset. The spacer im looking to buy looks like this...
I was wondering if the hub studs would be able to fit correctly once the wheel was mounted. Would it be better to get a 15mm spacer/ adapter from 4x100 to 114.3? Im stumped lemme know if you can help. Thanks.
You would want a 4x100 -> 4x114.3 adapter, so the OEM lug studs would go through the 4x100 holes on the wheel. 15mm will not cover up the length of the OEM lug studs, so clearance will be necessary.
saikou
Dec 3, 2012 04:42 PM
