aiming headlights
you can adjust the headlight angles on the top and bottom of the housing. upper adjustment would go diagonally from the top, near where the hood covers up the top of the headlight. bottom adjustment is straight down on the fender side of the bracket, look for a gear shaped toothed mechanism, turn it with a phillips screwdriver to adjust. i normally adjust mine about 15 feet from a garage door on a level driveway, and try to aim the majority of the light at the seam between the 2nd and 3rd door panel.
streetracerjoey210
Sep 17, 2006 12:36 AM
