EK Ignition sparked car will not start S2K Push Start.
Old Feb 3, 2011 | 05:48 PM
FRKWOO's Avatar
Default EK Ignition sparked car will not start S2K Push Start.
In the process of wiring oem s2k push start button and in the process of wiring the last wire which was the starter wire it shorted i guess one end of the wire touched the body of the car which grounded it and the other touched the white w/ black stripe wire connected to the ignition which set a big spark and since then nothing happens when second click of turning the ignition and car will not start and no accessories will function, i checked all fuses and nun were blown, what could be the problem/s? Thanks for the help in advance!
Old Feb 3, 2011 | 06:01 PM
habib's Avatar
Default Re: EK Ignition sparked car will not start S2K Push Start.
Check the main fuse under the hood
Old Feb 3, 2011 | 06:07 PM
FRKWOO's Avatar
checked that also...
Old Feb 3, 2011 | 08:27 PM
Wdpfreak145's Avatar
Hear your relays?
efdxjdm
10
Sep 28, 2009 01:59 PM
Noodler
Jun 13, 2009 09:44 PM
Jstnj03
Apr 26, 2008 11:07 AM
Synthead
Audio / Security / Video
Sep 3, 2005 11:16 PM
