88 civic radio wires need help
i got a honda civic 88 and i got a deck for it but i dont no how to installl it becuase the wire from the car and the wires from the deck are different and i need help on witch on is witch
http://www.pozitiveconnections.com/wiring_code.htm
check that site out that will tell you what all the wiring is stock...as for the radio my guess would be to go to kenwood.com or whatever brand it is and look at their wiring codes most of the time they match up pretty close to each other just remember striped wires are neg's and non striped are pos...and red is 12v switched, yellow is 12v constant, black is ground, and blue is power antenna/amplifier power...and if all else fails w/ audio wiring power the deck up and test the audios by going one at a time at FR then FL then RR then RL until u got em all right
