D16z6 2011 build
Well im starting a new build for 2011. I have figured out lost of problems and weak links in the sohc in the past few years. Last year i ended up racing on a broken distributor and didnt even now it till the season was aout over. Now its time that i have 2 of everything for this season
Car is gettin repainted by me soon as i get time and molding out the open areas in the front bumper
Special thanks to My sponsors for helping make this happen:
-Spec Clutch, Wiseco Pistons, LA Sleeve, AIP elecronics, GRP Connecting Rods, MandHTires.com, Crow Enterprizes, CNC Werx
Special hook ups for parts:
PFI Performance, Central motive power
my goal is to run mid to low 9's at 150mph+ here at high elevation colorado (5800ft) and hopefully faster out of state
Build specs:
D16Z6 block
- Wiseco Custom Pistons and Ceramic Coated
- GRP Rods/ Factory Crankshaft
- L.A. Sleeves W/ O-rings
- Comp Cam 59500
- Ferrea Valves, KMS Springs & Retainers
- wiseco Head Gasket
- ARP Fastener Head Studs
- Custom Intake Manifold/ 90mm Accufab Throttle Body
- Garrett GTX4294R
- Spec Mini Twin Disc
- Custom Trans w/ LSD
- 1200cc Fuel Injectors On E85
- 2 Intank Modified Walbro 255lph Pumps
- 10-Point Chromoly Roll-Cage certified to 8.50s
- Hondata S300 EMS
Build specs:
D16Z6 block
- Comp Cam 59500
- Garrett GTX4294R
- Hondata S300 EMS
yeah i sure hope so. ive never made a clean pass with the 42r. my best with the 42r was 11.28 shiftin at 6800rpms with a vitara build on 22psi. I dont know how much ive spent on the car.
and now it will have the new GTX billet 4294r
thanks. it doesn't look so good right now on the outside but im doin the body work this weekend and then paint it when i have a chance. it will be the same color
yeah as for out of state I never been but hopefully it goes good. gonna make atleast one of the IFO races in Kansas city, MO and a las vegas race.
Actually we didnt do too bad out of town but we definitely didnt gain much, if anything at all when we went out of town but thats cause our setup was not efficient at all. should be much better next year though
But hell, just ask us how hard it was to run high 9's from running low 10's lol we knocked down the 10's in one season... people arent lying though when they say its hard to go from low 10's to high 9's. Good luck this year though guys, its gonna be fun
ide love to see some 9 second d16's thats the engine i originally wanted to go with, but the shop i was dealing with at that time told me there was no way a single cam could run mid 10's lol (idiots)
speedfactory did well with theres last year, and you should do great with yours also man. just dont give up the dream and it will come true
people arent lying though when they say its hard to go from low 10's to high 9's. Good luck this year though guys, its gonna be fun[/QUOTE]
Thanks max yeah i cant wait to get it to the track already. We definitely gotta travel together to some races.
Thanks everyone. My spec twin disc is on order as of today. I also am having a D-series hand cuff made and it is the first one ever made and hopefully it goes well. ill keep you updated on that. sending the block out monday for the sleeves.
but the one may 1st we have a local race so im gonna attend that
Thanks everyone. My spec twin disc is on order as of today. I also am having a D-series hand cuff made and it is the first one ever made and hopefully it goes well. ill keep you updated on that. sending the block out monday for the sleeves.[/QUOTE]
Nice setup you have going. You mind shedding more light on your tranny setup? Alot of people who are doing high hp Ds are doing D2Bs and you are sticking with the stocker. I like that. Also what cam... the 59500 or a custom Comp grind?
Nice setup you have going. You mind shedding more light on your tranny setup? Alot of people who are doing high hp Ds are doing D2Bs and you are sticking with the stocker. I like that. Also what cam... the 59500 or a custom Comp grind?[/QUOTE]
Yeah its a d-series tranny with custom stock gear ratios. It has a jdm zc lsd big spline diff. A hand cuff is being made for the tranny. I am not tryin to be like everyone else. I wanna be the first turbo sohc in the 9s with a d-series trans. The cam is a 59500.
looks good!
couple questions... are you using off the shelf weisco's with the bigger wrist pins? i always thought the weisco's weren't that great for big power setups?
secondly; why not put the water res up in the front bumper or where the pass seat goes, might help in the traction department.
again not criticizing just curious
looks good!
I cant fit a big enough resivior up front cause the exhaust comes out the driver side bumper now and my battery is on the passenger side.
