Transmission & Drivetrain Gearboxes, Differentials, Clutches
600whp with a b16 trans
Old Feb 3, 2011 | 05:49 AM
550whpcivic's Avatar
Default 600whp with a b16 trans
Is a b16 trans to much for drag racing at 600whp? Are you going threw the 1/4 in 5th gear? What size tire are you using and would you switch to a different trans if you could?
Old Feb 3, 2011 | 11:29 AM
Honda Bull's Avatar
Default Re: 600whp with a b16 trans
It can be done. Absolutely. Just depends on tire size and revs. Assume 24.5" tires. Then you'll just have to see what the car actually traps vs. your rev limit. Simply saying 600whp isn't enough for us to predict your trap speed, so you'll need to find that one out and make changes based on that.
A 4.266 LS final drive may be beneficial depending on trap speed and rev limit though.
Old Feb 3, 2011 | 06:45 PM
I was thinking about the ls fd. I was looking on m-factory transmission calculator and it said I'll top out in forth gear at 127 mph and only reving to 8k with 24.5 slicks.
http://www.teammfactory.com/gearcalc...=0&trannytype=
Old Feb 3, 2011 | 07:49 PM
Honda Bull's Avatar
You're only revving to 8,000 rpm? What engine is this that you're making 600 whp with?
And what chassis? Depending on the weight of the car, you could be trapping anywhere from 130 -140+ mph with 600 whp. So like I said, it'll totally depend on what you actually trap vs. what you rev to. You'll just need to find out. If you only rev to 8,000 rpm with that power level, more than likely, you'll need to ditch the B16 trans.
Old Feb 3, 2011 | 10:27 PM
2.0L fully built lsvtec and I still have gsr cams and tuned bye myself. My last turbo setup with a top mount and a t3 60-1 on 15psi I made 400.6whp @ 8k. o yea 96 ek hatch.
Old Feb 5, 2011 | 03:49 PM
Aquafina's Avatar
If you wind it out in 4th to 8,500 you can get by with it if you use the LS FD. Otherwise GSR with a 4.05 or 4.266 will be what you need. With the 4.266 you'll have 1mph more at 8,000 RPM than with the B16/4.266 at 8,500 RPM. I'll take a look at the notes I made when talking to you and see which of the above would work better for you.
Old Feb 6, 2011 | 02:12 PM
Natural Aspirations's Avatar
If you need an LS final drive I have one cheap, PM me.
C Rex Express
Jan 23, 2014 07:54 PM
CHRIS S
Feb 16, 2010 02:42 PM
slammedobd1teg
Sep 25, 2008 02:31 PM
DA is best
13
Jan 29, 2007 11:09 AM
1 speedstar
Feb 10, 2003 05:34 PM
