REplaced CLutch still aint rite
Old Sep 24, 2002 | 09:38 PM
89 CRX SI's Avatar
Default REplaced CLutch still aint rite
OK i replaced my clutch cause wehn we took it out the PP was flat.
I got a barely used stock clutch. we put it in and all the flywheel was slightly burnt.
Now i got the pedal presusre it holds hard and all but wont quite grab hard. I havent adjusted it at all on the cable cause i just got home and its drak. do you think that could be the problem?
THX guys
Old Sep 25, 2002 | 06:50 AM
EF_LSVtec's Avatar
Default Re: REplaced CLutch still aint rite (89 CRX SI)
Adjust the cable and give it time to flush on to the flywheel. You usually have to resurface the flywheel and break the clutch in a bit...Give it a couple of hundred miles to set...and dont expect much of a grab from a stock clutch.
Old Sep 25, 2002 | 07:04 AM
89 CRX SI's Avatar
Default Re: REplaced CLutch still aint rite (EF_LSVtec)
it still should be able to lite em up and hit hard on the dash,,,,,, the clutch itself is broken in ill just give it time to wear in as you say. It is getting better daily.
dk4ever
Oct 17, 2008 05:11 AM
95GSRTT
Jan 18, 2005 05:16 PM
AznBlueBoy
Jun 25, 2004 12:41 AM
Goldfingiz
May 19, 2003 08:18 AM
