need help on d16z6 and d15b7
dude, yes. search like suggested above. there are NUMEROUS detailed write ups that will answer any questions you may have. if after reading it things are still unclear, then post up.
yeah it will work.. make sure you get the match ecu(p28), y8 headgasket (high comp), z6 timing belt(b7 &z6 are the same i believe), water pump and tensioner.. also make sure you pull out the oil jet thing between cyliinder 3 and 4 i believe..could be wrong but its in the middle of the block you cant miss it.. goodluck.
area608EG
May 17, 2008 03:31 PM
yz125rider21
Jan 11, 2006 09:39 AM
