ef wont start
Old Feb 1, 2011 | 07:15 PM
turbob16ferio's Avatar
Default ef wont start
i have a 89 civic hatch and it has a jdm b16a with a spoon computer... i baught the car about a month ago and the was running fine..... then the car started acting up recently.... the car will start in the morning just fine wen the car is cold i believe... but then when i turn it off it will crank but wont start... i checked for fuel and spark and then relized no fuel was being recieved... then i tryd replacing the evap sensor and recieved no luck.... then i replaced the fuel pump and still no luck.... but it seems that the car sometimes just dosent send a good signal to the fuel pump but idk...... so any help will be appreciated and any suggestions will be put to test...so pls ill try anything i can to make it start....thanx
Old Feb 1, 2011 | 07:59 PM
tonythetuner®'s Avatar
Default Re: ef wont start
Sounds like the main relay replace it see if it fixes the problem
Old Feb 1, 2011 | 09:02 PM
homebuilt503's Avatar
when your turning the ignition to the "ON" position before start, can you hear a click? and your fuel pump priming?
Old Feb 2, 2011 | 07:35 AM
sonicbob82's Avatar
^^^^^^^what he said...
Old Feb 4, 2011 | 10:35 PM
thanx to all for the help the main relay was it and ill b back to post q's in the future
DA9b0y303
29
Aug 21, 2013 03:51 PM
88EFsedan2
14
Feb 11, 2012 09:17 PM
Champs32
15
Aug 30, 2010 02:17 PM
LilMissCrystal81
Nov 19, 2004 11:26 AM
mikeg015
Jul 9, 2004 07:43 PM
