jdm B18c R Timing belt/water pump/tensioner
Old Jan 31, 2011 | 08:05 PM
del sol1658's Avatar
Default jdm B18c R Timing belt/water pump/tensioner
Been doing some searching and having trouble finding what I need..and im hopping you fellow type R owners won't flame me for posting this topic.
My 97 R has a 96spec JDM b18c-R and the timing belt was replaced by the previous owner however it shows a bit a play so I am led to believe the tensioner was not replaced.Belt also is not OEM.
So on to my question; which Timing belt/tensioner/Water pump fits to this motor?
According to http://www.itrca.com/FAQ/general/engineparts.php, I can simply use b18c1 parts? Are these all interchangeable?
My R is parked and im stuck sitting cramped in my s2k till I get this fixed
Old Jan 31, 2011 | 08:16 PM
kevinthefawker's Avatar
Default Re: jdm B18c R Timing belt/water pump/tensioner
just order all the b18c5 stuff its all the same , order the parts from the dealer or the online dealer.
Old Jan 31, 2011 | 08:18 PM
racebum's Avatar
all the gsr/itr part numbers interchange for this. smart move on your part changing this out
Old Jan 31, 2011 | 08:20 PM
14510-P30-003 TENSIONER, TIMING BELT (KOYO SEIKO)
14400-P72-014 BELT, TIMING (126RU26)
91213-PR3-004 OIL SEAL (29X43X8) (ARAI) x2 cam seals
91212-PR3-003 OIL SEAL (38X50X7.4) (NOK) oil pump seal
19200-P72-013 WATER PUMP (YAMADA)
all the parts you "should" order to do the job
Old Jan 31, 2011 | 09:29 PM
thank you to both you gentlemen. The ITR forum definitely receives better responses than other sections of this site.
I just want to make sure my car is reliable and when the time comes to pass heR on to a new owner he/she will be able to enjoy heR to heR full potential.
Old Jan 31, 2011 | 10:15 PM
racebum's Avatar
it does on some things, this forum also has more nose in the air argumentative; the itr is the best car ever people compared to the rest. sooner or later someone will bring up a post with the differences and be like SEEE that one weld right there makes the itr SO much better than a base with all the parts, it's like a completely different experience.
i seriously believe some itr owners in here would have sex with their car if they could
Old Feb 1, 2011 | 01:05 PM
1998GsRIntegra's Avatar
Completely true. Lol
egotistic
Apr 15, 2009 02:05 PM
dookeye
Dec 27, 2008 09:06 AM
zhen_fai
Aug 25, 2007 07:39 AM
Bobby
Nov 25, 2002 08:42 AM
