Chipped p72
If the ECU supports the butterflies then yes, it will open them. Unless you disable it.
The p72 is the stock GSR ECU, therefore should work unless the butterflies are removed or the intake manifold is swapped out for a single runner style (ITR, Skunk2, Edelbrock)
Not true, depends what he has done to it. If it's a bone stock car then the factory ecu is the best way to go. If not then a chipped ecu with the correct basemap would be the only and better way to go.
tree fingers
Apr 20, 2008 07:40 AM
