What do the numbers to these Rims Mean?
Old Jan 31, 2011 | 09:24 AM
ChrizXx's Avatar
Icon3 What do the numbers to these Rims Mean?
Like im trying to fin the difference in wheels i want and I'm not sure what to get because idk what these numbers mean.
NOTE: These are all the same Wheels just Different Numbers.
Rota J-SPL Wheels (15 x 6.5 / 4 x 100 / +35 )
Rota J-SPL Wheels (15 x 6.5 / 4 x 100 / +37 )
Rota J-SPL Wheels (15 x 6.5 / 4 x 100 / +40 )
Rota J-SPL Wheels (15 x 6.5 / 5 x 100 / +40 )
Rota J-SPL Wheels (16 x 7 / 5 x 100 / +40 )
So whats all these numbers mean?
Old Jan 31, 2011 | 09:51 AM
toyomatt84's Avatar
Sanji
Default Re: What do the numbers to these Rims Mean?
I'll just use one as an example:
The wheels dimensions: 15" tall, 6.5" wide
The bolt pattern of the wheel: 4 bolts at 100mm spacing
The wheels offset: +35mm
Old Feb 1, 2011 | 09:39 AM
ChrizXx's Avatar
Damn thanks man I understood everything but the offset whats that mean?
Old Feb 1, 2011 | 09:42 AM
singlecamslamed's Avatar
Stage 3 CLINGER!
Offset is the space from the center of the rim to the hub of the rim (where it mounts up). The lower offset you have, the bigger the lip will be and the more the lip will stick outside of the wheel well.
Example:
Old Feb 1, 2011 | 09:46 AM
speedooo's Avatar
Per say you have a 15x8+0 wheel...with a 0 offset, the hub will bolt to the wheel directly in the middle (4" to the inner/outter rim from mounting point) of the rim. A positive mounting point will bring the mounting point closer to the outsider; negative pulls the mounting point inside.
It's moderately confusing because wheel height and width is measured in inches and offset is in mm.
Old Feb 7, 2011 | 12:03 AM
94GSRlbc's Avatar
perfect
my00civic
Jan 9, 2011 06:03 PM
timisyourfriend
Apr 30, 2007 04:34 PM
CBEengineering
11
Apr 16, 2006 08:15 AM
diewX3
May 10, 2005 08:59 PM
