H22 to F22 swap
Old Jan 31, 2011 | 08:22 AM
Mud_Fox's Avatar
Default H22 to F22 swap
I recently bought a 1995 Honda Prelude shell and I got a hold of a F22 engine with a 5 speed tranny for it. I was wondering if I could use the wiring harness from a H23 or H22 with the F22? I do know I have to use the H22 or 23 throttle body in order to use the ECU that's for a H22 / 23.
Old Jan 31, 2011 | 10:10 PM
InvaderTrax's Avatar
Default Re: H22 to F22 swap
What's this about having to use an H22 throttle body? You could use a D16 throttle body and it would still work. Anyway, the harnesses are basically the same. You'll have unused plugs for VTEC and knock sensor
Old Feb 2, 2011 | 08:11 AM
Mud_Fox's Avatar
Alright cool, Thanks. As for the throttle body I was only told that I'd have to use the H22 throttle body but since I got a H23 with a bad rod I was going to use that one.
Old Feb 7, 2011 | 09:47 AM
rimsandthings's Avatar
yes h23 parts bolt right on
Old Feb 8, 2011 | 07:57 AM
Mud_Fox's Avatar
Awesome thanks! Now that that worry is gone I am now tearing into the dash to see if or why my fuel and temp gauges stopped working. Has a poof of smoke come out of dash shortly after hooking up the wiring harness so thinking I crossed a wire and fried them.
Thanks for the help both of you
MJT805
May 8, 2009 11:16 AM
ludaboy93
Feb 2, 2006 01:22 PM
btleier
Sep 24, 2003 11:08 PM
EuRoBrO
Jan 25, 2003 03:37 PM
WuWarrior
Oct 18, 2002 08:19 AM
