Trailing arm bushing DX and Si different size?
Old Jan 31, 2011 | 03:32 AM
CWBETB's Avatar
Default Trailing arm bushing DX and Si different size?
Did a rear disc conversion the other day on my 1990 Civic DX Hatch with drums using 90 CRX Si rear Discs. I wanted to use the bushings from my old trailing arms but oddly enough they are smaller then the ones that are in the CRX arms. I thought they are all the same? The arms are supposed to be from a JDM CRX si "Sir?" if that matters at all. I was thinking maybe they are actually DA Teg arms, but all the parts I ordered "rotors etc" fit fine, didnt the DA have a larger rotor? Help the confusion! thanks
Old Jan 31, 2011 | 09:33 AM
dc5itracer's Avatar
Default Re: Trailing arm bushing DX and Si different size?
No all rear rotor sizes are the same but the DA trailing arm has a bigger bushing get a Da bushing
Old Jan 31, 2011 | 09:42 AM
CWBETB's Avatar
Thanks, pretty solid its DA arms then
Old Jan 31, 2011 | 09:52 AM
Tyson's Avatar
The DA is a bit bigger. The normal bushing can fit inside the DA bushing casing, you just need to cut it all out and press it in.
Check the FAQ for wes vanns page and his write up.
Old Jan 31, 2011 | 09:53 AM
dc5itracer's Avatar
http://www.performanceforum.com/wesv...g/bushing.html
Old Jan 31, 2011 | 09:54 AM
dc5itracer's Avatar
Yeah u can do what tyson said they say the smaller one feels stiffer then the bigger one
Old Jan 31, 2011 | 10:18 AM
CWBETB's Avatar
Good info! thanks all!
greenEFhatch
Aug 18, 2011 08:46 AM
wickedEFguy
Jun 23, 2009 03:07 PM
ED9man
21
Jun 7, 2006 05:07 PM
Fishcat37
11
Apr 9, 2003 11:16 PM
shortyz
Oct 18, 2002 10:32 AM
