brake problems and ABS light
Old Jan 30, 2011 | 08:26 PM
NOTUNINGNONADA's Avatar
Icon2 brake problems and ABS light
Ok, for quite some time now i have been driving without using the pedal to stop my car and i need to correct this problem ASAP.
PROBLEM: front right caliper will start to lock up when car is in motion...
Things that i have done: Changed rotor, Changed caliper, Changed pads, Changed Brake hose...
Vehicle: 1993 Honda Ex sedan with 4 disc brakes
Solutions to move: Leave bleeder valve open and use e brake as an alternative way of stopping...
Tax time is around the corner and i need to show these country boys here in arkansas what tuners are made of...Thanks for the help..
PS: My speedometer sometimes reads and other times just floats givin inaccurate speeds..
Old Jan 31, 2011 | 06:33 AM
Default Re: brake problems and ABS light
23 VIEWS AND NO ANSWER??? Come on yal!!
Old Jan 31, 2011 | 06:50 AM
grumblemarc's Avatar
The Grumpiest
Master cylinder? Brakes are kind of simple.
Edit. You also have ABS. Not so simple. Is that working properly?
Old Jan 31, 2011 | 07:42 AM
Former User's Avatar
Does fluid flow freely out of the right front caliper when bled?
Is the ABS light on?
Speedo:
Is the CEL on?
Old Jan 31, 2011 | 10:40 PM
Speedo:
Is the CEL on?
Yes when bleeding the right caliper it is like all the rest flows out good..but when the bleeder screw is tightened i can go less than 2 miles before the caliper starts to grasp the rotor....but i can crack the bleeder valve open just a bit and it doesnt clamp down...thats how im driving now...
ABS is on and so is the CEL...but i know what the CEL is for...
Old Jan 31, 2011 | 10:42 PM
changed master cylinder....bench tested it correctly and everything...
Old Feb 1, 2011 | 07:48 AM
What ABS trouble code is thrown when you jump the service connector? This may give you a hint about the problem.
octodigitus
Honda Civic (2001 - 2005)
Jun 18, 2021 12:16 PM
malilaz
Suspension & Brakes
Nov 23, 2013 12:42 AM
monkey508
Jun 29, 2008 12:45 PM
kenneyd
Feb 23, 2007 07:24 AM
alfer
Jun 7, 2003 03:45 PM
