H22A parts for sale and more
Old Jan 30, 2011 | 03:46 PM
pjschmitt's Avatar
Icon5 H22A parts for sale and more
Hey guys, I got a small collection of Honda parts for sale, mostly stock JDM parts that I removed and replaced with other stuff. Everything is OBD1 H22A or F22B1
Starting at the top of the engine:
Throttle Bodies - 2 or 3 of them and misc sensors
Upper plenum intake manifold - One or two for average prices.
Middle intake portion, IE Butterflys, uncut ready to stack or mod like blacktrax.
Middle intake portion without butterflies - They were pulled out but nothing cut.
Lower portion intake - one only. JDM not modified.
Misc sensors for upper end please inquire.
94 Prelude JDM H22A Stock Cams with gears.
Valve cover - original paint a little scratched up
94 accord EX Power Steering Pump - Hoses cut off at rack, works 100% perfectly comes with radiator and lines and bracket and resevoir.
94 Accord EX F22B1 knock sensor.
94 Accord EX A/C system - comes complete. Great working compressor, all lines and some electrical parts from under the hood. I even removed the cooling part out of the A/C box under dash. All components even the electrical parts.
94 Accord EX F22B1 Axles - all 3 available one needs boots, centerpiece with work on F or H engine.
h22a crank pulley harmonic balancer. a little chipped but works fine. 6 ribs
H22A - knock sensor, o2 sensor and TPS sensor.
AIR BAGS - pass and driver, perfect and intact.
Steering wheel OEM
ABS - complete system - Main unit, rear brake prop valve, electronics, etc.
94 Accord EX Brake system - Perfect working condition, pulled to swap to non abs brakes - Power Booster, Master Cylinder (ABS)
Headlights - a little foggy o/w all good. DOT
Motor mounts for manual transmission - top condition.
A few obd0 ecu's cheap.
Set of 4 KYB GR-2 - These shocks were installed and drive on about 3500 miles. I got new ones to replace so these are going cheap and hopefully quick.
That is not all of it but this is what I could think of right off the top of my head.
Pics available upon request.
All items are for sale as a "give me your best offer and I will only add shipping to it."
Please let me know if there is something you are interested in or have a question about.
P.S. Interested in trading for:
HID Kit 6000K for my 94 accord
Large steering wheel like 16 or 17" that is black metal and black grip or any woodgrain
pillar mount gauges - oil pressure, water temperature 2 pod only.
alternator bracket relocator
Old Mar 24, 2011 | 09:48 PM
pjschmitt's Avatar
Default Re: H22A parts for sale and more
Items are sold as of 3/15.
Old Apr 20, 2011 | 10:44 PM
MansuDC2's Avatar
how much for the 94 accord EX abs unit just the main unit with reservoir?
Scott Little
Mar 12, 2018 07:03 AM
pjschmitt
Apr 1, 2011 10:40 AM
Alstare
May 2, 2002 07:50 PM
