cel after 5k rpm?
Old Jan 29, 2011 | 09:25 PM
k0rupt_ed's Avatar
Default cel after 5k rpm?
Hey guys, I recently purchased a gsr with a b16 in it (swapped) I'm having a issue after passing 5000 rpms for a brief period of time the engine will cut power and throw a check engine light. Could anyone possibly shed some light on somethings it can be?
Car is a '99
Old Jan 29, 2011 | 10:15 PM
mouab18c1's Avatar
Default Re: cel after 5k rpm?
Pull over after you get the CEL and jump your ecu for the CEL code.
Don't know how to do so? Look in the FAQ Thread
Old Jan 30, 2011 | 09:25 AM
k0rupt_ed's Avatar
its the blue plug right? when i jumped it it blinked the abs light instead O.o
Old Jan 30, 2011 | 09:33 AM
mouab18c1's Avatar
Yeap it's blue right under the dash on the passenger side.
Old Jan 30, 2011 | 12:21 PM
k0rupt_ed's Avatar
i jump it and the abs blinks instead
Old Jan 30, 2011 | 12:29 PM
mouab18c1's Avatar
That's odd!
What codes are you getting from your abs light?
Old Jan 30, 2011 | 02:23 PM
k0rupt_ed's Avatar
i took a video of it, looks like 91 and 11 maybe?
but the car feels like it goes into a limp mode state if I put it onto anything over 5 thousand rpms. very weird. I'm wondering if I have the correct ecu in it since its now a b16, but I can't be sure its a p72 I believe?
Old Jan 30, 2011 | 02:31 PM
mouab18c1's Avatar
Take the ecu out and see what it says on it.
Old Jan 30, 2011 | 02:33 PM
k0rupt_ed's Avatar
bar code says p72
Old Jan 30, 2011 | 05:11 PM
k0rupt_ed's Avatar
scanned the code:
p1259
Manufacture control fuel air metering.
So my question is it the ecu?
should it be a p30 instead of a p72?
Old Jan 30, 2011 | 05:14 PM
mouab18c1's Avatar
Yes you need the proper ecu for that motor.
p30 is what you need.
p72 is a gsr ecu
shortlid
Mar 15, 2006 05:04 PM
roadawg
Mar 5, 2003 03:37 PM
Cozmo Kraemer
Feb 17, 2003 12:26 PM
