1992 Accord wont start
Old Jan 29, 2011 | 11:22 AM
djfehr's Avatar
Default 1992 Accord wont start
1992 5 speed manual transmission accord intermittently wont start when outside air temp is above 25F. last time it started when out side air temperature was below 15F. ran fine once started & has not died while running. battery is fully charged & engine cranks/turns over normally. overhead cam is turning. fuel pump runs, fuel in fuel rail, fuel flows from pressure regulator. blue spark at spark plug. resistance at each pin of injector resister connector is 6.5 ohms. injector resistance is 2.5 ohms. voltage at injector fluctuates between 9-11 volts. spark plugs are a light tan color. engine cranks without a hint of cylinders igniting.
Ideas on what could be the problem?
Thanks in advance
Old Jan 29, 2011 | 01:25 PM
nus_dogg's Avatar
Default Re: 1992 Accord wont start
If you have gas and spark, only thing I can think of is compression?
Old Jan 29, 2011 | 02:14 PM
curtie94's Avatar
sometimes you think the fuel pump is running even though it isn't fuel. your fuel pump might be dieing.
Mike Dulin
Dec 7, 2018 09:49 AM
russian239
Sep 19, 2014 07:19 AM
Jaredart
Mar 12, 2014 03:28 PM
SteveL57
Jun 24, 2011 03:59 AM
bri1998
Jan 8, 2008 09:18 PM
