poor mans r weird noise need help!!
Old Jan 29, 2011 | 09:28 AM
Pagley's Avatar
Default poor mans r weird noise need help!!
So I have a p72 block with jdm itr internals w/ pr3 b16 head supertech valves & valvetrain and itr cams, just got done assembling the motor and tried to start it and I hear this weird grinding noise when I tried starting it and it hesitated to start and if it started it would not run for longer then a second, and kept backfiring every now and then, so I took out the spark plugs because I thought something wrong was with the block but when I try to start it with the plugs out, it sounded fine no grinding noise. As soon as I put the plugs back in and retard the timing a little bit it would still make the same noise. Anyone have this same problem? Any solutions?
Old Jan 29, 2011 | 04:12 PM
camal's Avatar
Default Re: poor mans r weird noise need help!!
Dizzy? Can you tell where the noise is coming from?
Old Jan 29, 2011 | 06:44 PM
TJChad's Avatar
I would tell you to post a video but continuing to try and start a engine with a grinding noise isn't really a good idea. have you tried turning the engine over slowly by hand and listening for any noises or being able to pinpoint the area or location?
markturbo
Honda Civic (2006 - 2015)
Mar 31, 2009 11:55 AM
EK45VTi
15
May 2, 2007 10:16 PM
ek4h
Apr 5, 2007 05:19 PM
RTW DC2R
Apr 28, 2006 12:44 PM
Rionmann
Jan 12, 2006 10:57 AM
