Exhaust setup. ITR headers
Forgot to add it's on a daily ls vtec. Built head stock block. Gonna build the block once I hear back from Benson and eventually superxharge it.
What do you mean by taper?
have a tapered connection, like a funnel. not just connect the 2.5" to the 2.3" and clamp the big one down onto the small one to force it into fitting.
Thanks for super fast responses. Is A resonator gonna restrict flow?
I have horrible low end but I also have holes in my header and piping. Figure going to 2.5 and no leaks or holes is gonna help that.
On my 00 GSR i have the
T1R Response Header > TIR Resonated Test Pipe > T1R B-Pipe > ITR Axle Back
Absolutely Love It!
Sound is nice and low key until full throttle. Even then most of the
tone is from my intake, 3" pipe > BPI stack > K&N Filter.
Im in the process of building a 2.5" cat using a magnaflow unit. Just waiting on the flanges. That will make it even more low key im sure.
If you search my username im pretty sure i uploaded sound clips for another member.
Absolutely Love It!
keep your cat. whoever says it sounds better either has tons of resonators, likes bees, or can't hear. plus trees will thank you.
otherwise you'll be spiffy.
resonators don't restrict flow. or if they do not much at all. they are straight through just filled with packing for sound deadening.
Here ya go
T1R Header > T1R Test Pipe > T1R B-pipe > ITR Axle-back
Sound clip inside car window half down full throttle gears 1st to 3rd
http://www.youtube.com/watch?v=zW5mtCSir7g
Sound clip inside car window closed NYS Thruway downshift 5th to 3rd
http://www.youtube.com/watch?v=3PkdZ...feature=relmfu
Sound clip inside car window half down part throttle city driving
http://www.youtube.com/watch?v=wKyWu...feature=relmfu
Sound clip inside car window half down part throttle city driving gears 1-4
http://www.youtube.com/watch?v=AsUgp...feature=relmfu
Sound clip mic next to muffler
http://www.youtube.com/watch?v=Kotu8...feature=relmfu
T1R stuff is hella nice. Had their B-Pipe and Axle back on my DC5 years ago. If I wasn't going sleeper route I would get their exhaust for my EK but I got a hella quiet RSR right now. Ordered their Bmax suspension for my EK. Should be here soon.
