Whats the max i can sleeve my H23 Block?
Old Jan 28, 2011 | 10:00 PM
rumo1112's Avatar
Default Whats the max i can sleeve my H23 Block?
Ok guys, i'm swapping a h22 head onto a H23 block, but i want to sleeve it, I want to max it out. So whats the max mm i can sleeve the block to. And also what size Valves would i have to use when maxing out the size on the H23 block?
I don't know the what the sizes are on the valves. Are the Exhaust valves smaller than the intake valves?
I know the stock bore on the H23 Block is 87mm, so how big can i go? lol
Old Jan 28, 2011 | 10:34 PM
rumo1112's Avatar
Default Re: Whats the max i can sleeve my H23 Block?
I figured it out the Intake valves are 35mm and the exhaust valves are 30mm
Old Jan 29, 2011 | 06:04 AM
Ledslnger's Avatar
I would just call a sleeve manufacturer like Darton, (because they have quality stuff) and ask them what their biggest is for the H23....or go to their website. Then you can start looking for what pistons to use, etc.
Do you really need to sleeve it? How much HP are you looking at pushing?
Old Jan 31, 2011 | 08:57 AM
Golden Eagle's Avatar
What size to bore H-23? The sleeve bore size I would go with is 88mm and a maximum of 91mm can be done but I would stay at 88mm.
If you plan on boosting over 20lbs then 89.5 is the largest you can go with the ''O'' ring groove.
KEEP CALM and CARRY ON with G.E.
Old Feb 6, 2011 | 01:18 PM
Sandhonda's Avatar
ERL in Indiana suggests a max of 90mm.
beasty=eg
Nov 6, 2010 12:54 PM
BoneStckCivic
Oct 21, 2003 02:11 PM
BoostedH23a1
Apr 10, 2003 06:16 PM
superlude01
Dec 3, 2002 12:49 PM
