Baring My car.
Old Jan 28, 2011 | 05:43 PM
cedrichawkda6's Avatar
Default Baring My car.
I decided to bar my DA. I have a B16a OBD0. I bought Skunk2 Manifold, Obd1 Injectors and Clips, B16a Exhaust mainfold, NGK 4 wire O2 sensor, and a Rywire Jumper Harness and B16a ECU USDM. I'm pretty sure I have all the components to convert to OBD1. I'm going to be Baring it for a 92-95 Del Sol. Does Any one have any other thing they think I need Or should do to Pass the Ref? I would appreciate positive input.
Old Jan 29, 2011 | 08:51 AM
emooheo's Avatar
Default Re: Baring My car.
if the engine is older than your car then you cannot bar it. Jumper harnesses cannot be used either. You are not going to be able to bar your car with that motor
Old Jan 29, 2011 | 08:57 AM
Got that all handled
Old Jan 29, 2011 | 09:30 AM
mattyfo0z's Avatar
You won't pass if the motor is older than the year of the car, and you definitely won't pass with a jumper harness. Why do you want to BAR your DA as a Del Sol instead of just a DA with a swap?
Pworld925
Mar 7, 2009 10:14 PM
dem0nk1d
10
Dec 31, 2007 07:15 PM
mynameizstitch
Aug 30, 2007 08:44 PM
rextec
10
May 28, 2005 12:26 PM
Luserkid
19
Nov 9, 2004 04:34 PM
