EG Parking Pole Wiring Black and Red
I want to know
where do the Black and Red wires from the
92-95 EG JDM parking pole
connect to on the car the ****FACTORY**** way.
I already have the factory (yellow/red) and (yellow/white) JDM harness to switch.
im only missing the black and red side which is seperate.
Heres a good pic a found online.
Unless you have JDM Headlights with "City Lights", there's no point. You're missing an adapter harness which plugs into the City Lights, which you don't HAVE on your USDM headlights. So, just tap into RED/BLK and BLK and be done with it. Don't believe me? Here's some photos.
thx a lot for the info. it's exactly what i needed to know.
Now i just need to find ""that"" harness that way i can also follow a DIY for city lights in USDM headlights or maybe pick up some JDM ones.
thx.
thx.
LOL. Good luck finding it. I would just make it myself if I were you ... in fact this thread has inspired me to look up where to find the proper connectors to do just that (from a 92-95 Civic).
2-PIN BRN (F) (Flat) = Connector for the sunroof motor (on the roof)
2-PIN BRN (F) (Square) & 2-PIN WHT (M) = Washer motor connectors - not sure if front or rear washer (these are different, but one will be identical)
Even if the plug for the side markers was the same as the city light connector, you would only be able to use the parking pole when the PARKING LIGHTS were turned on... connecting the red/black wire to a 12v switched source and grounding the black wire in the original kits city light plug provides the necessary connection to run the parking pole when the car is on.
