FS/FT: CRX, EF9, EF8 and RTwd Parts
Most of you know the story, but ive gotten to a point where i need to slim this stuff. Can no longer "hope" for anything other than starting fresh. All of this stuff is in good shape, and pics are of actual stuff. Some have been cleaned before pics, some havent. I know, thats lazy. But for now i just need it all listed. If you need better pics, ill freely text you some after i clean em up....reassurance is fine by me...
PM me here, email at maxwellduryea at gmail dot com or text at 505.450 seven zero eight five
prices dont include PayPal fees or shipping, of course....local is best and hell, ill even make ya a package deal.
will i trade for stuff? sure. i need a few things:
EF9 front bumper support
Built NA d16 longblock
that's it...
yep, its hit that time. ill be selling the full CRV/Bseries into RT4wd wagon as a complete kit. I would have thought someone woulda taken the whole car, but this way i can sell it easier and make $$. This is everything to make it install into your wagon. the transmission side motor mount (thats part of the chassis) will need to be drilled out and moved an inch or two back towards the firewall, but thats cake...
here's whats included:
1998 CRV 5speed transmission. perfect shape. shifts great and just flushed with MTF. blox magnetic drain bolt
Hasport motor mounts. Trans one is customly made by Shenrie
BRAND NEW Denso starter. Brandddd NEWWWW
CRV rear differentials (2 seperate units) both low mileage
Rear differential subframe and custom busings
Front subframe (already notched)
CRX Si manual steering rack (just rebuilt - 0 miles)
Custom CRV driveline and driveshaft
CRV/RT4wd rear axles, custom built by Shenrie (i replaced all the boots and inners few months back. OEM Honda)
All associated hardware, bolts, nuts, etc....
Seeing as though so much interest is in these items, and how many BRAND NEW parts are installed, i'll be wanting $1,500 cash. Come pick it up...not shipping unless you arrange
OEM CRV 5spd leather stitch **** and brand new OEM ITR shift boot. **** used for a few months, and boot has never been installed...
$25 a piece, $45 for both....
Momo extended hub for Civic EF/DC $30
Walbro RT4wd fuel pump. Brand new, installed, started, pulled. Whole unit as seen in the pics. $70
NGK plug wires for DOHC VTEC B Series. Brand new. $45
Good Shape RT4wd sunvisor, no tears. Needs a good cleaning $10
Random Grey pieces, good used shape. $10 a piece
Grey rear ashtray for ebrake console $10
1991 RT Engine bay fuse box. One hinge tab has a snapped piece but still opens, closes with the other one just fine. Everything is there tho. Painted oil rubbed bronze. $20
1991 RT passenger fender. From my NM car. Rust free, 135,xxx miles, originally RioRed, and got dented while removing the transmission. I had Bondo'd it, and was fine until some jackass leaned on my car and cracked it. No time to do bodywork, so someone else can. The bondo is thin, look at the images. I had used gafers tape to disguise it. hahaha.. Otherwise its in good shape (also, its cut for sidemarkers...) $50
Front EF/CRX Suspension Techniques 7/8" sway bar. I tried installing, but cant lift her up enough to install without removingt he driveshaft. cant be fukd with that right now. Going to run without one for a while! This is brand new, has some scratches from (trying to ) install, and includes the brand new bushings and ill throw in my Energy endlink bushings. Maybe 3k miles on them. Cheapest i could find was $180 plus shipping, so ill do $175 shipped http://www.summitracing.com/parts/STQ-50142/
OBD1 injector clips. No longer need...Great shape, nothing broken, plenty of wire $15
Japanese replica license plates. Ive had these for a long time, no idea i still had them. They havent been used, they are new and look great. $25 (for the white one, yellow is sold)
Full set of moldings and rocker panels. all are PlastiDipped and look great. Again, these were going on my car, but it has since been abandoned. Pics dont do them justice. They came out really well. All of them have been refinished very well.
$100 for the rocker panels
$100 for all 4 window sils/moldings
$50 for the passenger side window sils
mint S2000 cd player/radio with included jumper to plug and play with EF, silver face, glows amber $65
ITR cd player glows white, includes code, legit and not stolen, plug n play for EF's. Such a clean oem look $50
Subaru roof rack x2 $50 (removed from car, nothing done to it) and $100 (completely refinished - pictured below)
Custom 3 bike rack for RT with existing roundbar setup. bolt on and GOOOOO $130
RT4wd Keyset, door handles, both ignition and rear hatch.. and ignition switch, three keys- $75
1989 RT4wd stock mounts (rear diff and balancer and front radiator support mount) all in great shape, no tears, no rust, pretty dirty tho $40
RT4wd Rear license garnish x2 $25(stock/unrefinished - 2nd pic) and $70(refinished see below)
good shape 1989 RT4wd taillights, drivers has two tiny "drain holes" hadrly , includes all bulbs and harnesses $75 (will split up at this point - $30 for either outter, $20 each inners) (pass side outer sold)
PSWDJDM front strut bar for use with B series and ITR throttle body (to clear map) $100
RT4wd tilt steering column X2 $50 each
Rt4wd rear metal taillight covers $20 each
EF Battery tray, periwinkle blue with AC line mount $20
OEM Rio Red Battery tray, plastic tray, tie down and anchors and AC bracket. Great shape. Installed a ODYSSEY 680 so this needs a new home. Included is everything in the picture. Id refinish the tie down with wrinkle black and you're set. $30
EF Wagon Hood hinges, periwinkle blue, minimum surface rust (NM car!) $20
1989 rt4wd Radiator support. completely stripped, polished and acid washed. now has a bit of a "rusty look"....easily polished back. (that "new chrome" or whatever would do it in seconds, might be able to do myself) also a terrible photo...will remove, polish and replace photo...$75
Gas door, stripped to bare metal $15
Pretty much minty 91 RT4wd center vent. All flaps work and nothing broken. $40
Spare clocks/Vents (sid vent, horzontal flaps broken as you can see) and center vent perfect minus outer piece, working clock glows REDDD, also they are dirty as ****, sorry! $25
1989 RT ebrake assembly, no cables $45
1989 RT4wd steering column switches n ****, some wear on white lettering, works great tho! $30
Subaru Legacy maplightz n storage. needs to be refinished. simplegreeneddd. works great and complete. for custom install on wagonn $20
1989 RT4wd heater blower. Was replaced before i bought the car, and hasnt seen much of any winter at all...great shape. $75
Rear hatch hinges, stripped to bare metal $20
Mint and labeled 1991 RT4wd underdash harness $100
Mint 1988 RT4wd underdash harness $75
Door moldings (grey) , all of them $20
LHD civic hatch EDM cubby insert $70
2001 BLACK GSR leather seats, great shape with wagon brackets (88-89) $250
Under dash and engine bay fuse blocks $10 each
illl update pics as i get them/time/life/women permit...
that's it...
Both lips are pending. As is the flywheel, b16a swap, spoon mirrors, and DA armrest.
Let's move the rest of this!
Thanks for the bumps, fellas! Helping fellow EF lovers, love ittt
can you send Pics?
and whats this??
EF9 SiR Rear Long LED wing....great shape, just needs primer and paint. no cracks or chips, LED was just professionally polished. No longer own a EF9...$220 shipped
Listed a set of RSX type s seats, updated the list and lowered prices!
Let's get this stuff sold! Thanks to everyone that's helped!
I just got the wing primered and wetsanded yesterday...
It is still looking for a home! Pm me!
And the IM, I could do $90 shipped as postage fees will be a bit expensive...
