Identify this device on the F22A1 intake manifold!!!
Old Sep 24, 2002 | 06:38 PM
GimpyAccord's Avatar
Default Identify this device on the F22A1 intake manifold!!!
As the title says...
what in the hell is that!? I lent my helms to a friend for a bit.. and cant look it up. cant seem to find it on hondaautomotiveparts.com.. or i'm stupid and not seeing it.
its not had anything hooked to it for YEARS, and while looking over the EGR to remove it, i realized i should shitcan this too since its seemingly unimportant.
PS the arrow might be somewhat misleading. i mean the big thing on top..i know what the bottom one is.. intake air temp sensor.
[Modified by GimpyAccord, 3:39 AM 9/25/2002]
Accord94DX's Avatar
Default Re: Identify this device on the F22A1 intake manifold!!! (GimpyAccord)
hm. Reverse kickback actuator? Hell if i know maing....
Old Sep 24, 2002 | 06:42 PM
Martaigne's Avatar
That's yer canootin' valve.
Old Sep 24, 2002 | 06:50 PM
Default Re: Identify this device on the F22A1 intake manifold!!! (Martaigne)
obviously its not imporant.. since ist not doing anything.
doesnt that always boggle you when you removie expensive sensors/valves... and nothing happens?
Old Sep 24, 2002 | 07:26 PM
Gennady's Avatar
New User
Iat?
Old Sep 24, 2002 | 07:36 PM
jweller's Avatar
Default Re: Identify this device on the F22A1 intake manifold!!! (Wont be beat)
Flux Capacitor?!
Old Sep 24, 2002 | 07:39 PM
H23 Power's Avatar
Default Re: Identify this device on the F22A1 intake manifold!!! (jweller)
edit: starting air valve
[Modified by F23 Power, 10:42 PM 9/24/2002]
Old Sep 24, 2002 | 07:54 PM
Steve04SVT's Avatar
Default Re: Identify this device on the F22A1 intake manifold!!! (F23 Power)
That my friend, is a stock Honda turbo. I believe it only spools up around 12,000 rpm. GOT BOOST? J/K. I'm not to sure, but if I find out I'll let you know.
Old Sep 24, 2002 | 07:59 PM
greensleeper's Avatar
Default Re: Identify this device on the F22A1 intake manifold!!! (Steve96Accord)
BWAHAHAHAAAAHAHAAHAAAAAAAAHAHAAAA
that kills me........................
Old Sep 24, 2002 | 08:02 PM
Default Re: Identify this device on the F22A1 intake manifold!!! (greensleeper)
that turbo must be hosed then...
because im only seeing .00069 boost.
Old Sep 24, 2002 | 08:06 PM
thanks...
my car seems to start fine without it.. odd.
Old Sep 24, 2002 | 08:57 PM
CardDealer's Avatar
Banned
Modified by CardDealer at 4:14 PM 11/17/2006
Old Sep 24, 2002 | 08:59 PM
CardDealer's Avatar
Banned
Default Re: Identify this device on the F22A1 intake manifold!!! ()
Old Sep 24, 2002 | 09:03 PM
CD8's Avatar
CD8
Default Re: Identify this device on the F22A1 intake manifold!!! (schlit)
thats basically what this msg board is made up of... you have to sift through a lot of bs to find the good stuff, but the good info is daym good.
Old Sep 24, 2002 | 10:59 PM
ArchAngel Sabastian's Avatar
New User
Default Re: Identify this device on the F22A1 intake manifold!!! (exaccord)
that is not a FIV... FIV uses coolant to open. and its basically on the TB.
i cant really see if theres anything comming in out of it gimp umm so.. is there? ill have a look in the morning.
[Modified by ArchAngel Sabastian, 2:01 AM 9/25/2002]
Old Sep 24, 2002 | 11:03 PM
New User
I sense a lot of sarcasm and post whoring on this site and not so much help....what's goin on?
if your going to complain ok, if your going to complain about the lack of good info and then supply bad misleading info. your not really doing anything.
Old Sep 25, 2002 | 07:02 AM
Default Re: Identify this device on the F22A1 intake manifold!!! (ArchAngel Sabastian)
Actually on the F22A1 that thing on the front of the IM to the left is the FIV. (notice how its kinda new lookin from being replaced ) and to the left of that.. the black circular thing is the EACV. They moved stuff around on the newer accords.
there is nothing coming out of it.. used to be a vacuum line on it, i have no clue where it went to.. been years.
Old Sep 25, 2002 | 07:12 AM
okay guys its what F23 Powaaaah said (was there ever a doubt )
found this on usenet
Air boost valve: on the far right of the TB...boots air intake to ease
starting.
After doing more and more research the car can live fine without it. In fact if this valve sticks open (which many seem to do) it'll cause the car to stall because its letting too much air in.
mine must be stuck shut, because from what i can tell vacuum from the intake manifold is what closes it (when car is running). I have no vacuum on it, so in theory it should be OPEN to give more air while cranking and the car would stall by it being stuck open.
[Modified by GimpyAccord, 8:14 AM 9/25/2002]
Old Sep 25, 2002 | 07:16 AM
so it IS a miniturbo... what is that like a T.3?
Old Sep 25, 2002 | 07:46 AM
SOHCArchangel's Avatar
b&m fpr
Old Sep 25, 2002 | 12:13 PM
Default Re: Identify this device on the F22A1 intake manifold!!! (SOHCArchangel)
is that the purple thing?
Old Sep 25, 2002 | 12:42 PM
yah.
its there for nitrous.
i will be selling it soon .. or maybe giving it away if somone wants it. I think i'm going to switch to an Aeromotive regulator.
SuM Honda
Feb 11, 2009 05:32 PM
7808
Mar 30, 2006 04:33 PM
Speedra500
Jan 22, 2005 07:10 PM
koco
Feb 16, 2003 02:37 PM
warfa
Oct 21, 2002 01:38 PM
